Thread started 02 Apr 2007 (Monday) 23:40
Whats more important CPU or RAM?
fredmitcham
Apr 02, 2007 23:40 |  #1
I have an AMD Turion 2ghz w/ 1gig ram. If I can only upgrade one of the two, either to a duo core processor or to 2 gigs of ram, which would give me the biggest benefit in photoshop? Thanks
Tony-S
Apr 02, 2007 23:46 |  #2
RAM, RAM, RAM!!
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Bubble
Apr 02, 2007 23:58 |  #3
crank up as much RAM as you can. It will help you a lot. :)
Canon 5D II, 7D | 16-35L II | 24-70L | 24-105L | 50L | 85L II |  iMac 27 | Redrock Micro DSLR Cinema Bundle | Elinchrom Ranger RX-AS Kit| Elinchrom Digital Style 1200RX/600RX | Turbo SC |
August ­ 15 ­ Photography
Apr 03, 2007 00:29 |  #4
RAM no doubt
Oooooh they have the internet on computers now. - Homer Simpson
Cameras and Computers
cosworth
I'm comfortable with my masculinity
Apr 03, 2007 00:37 |  #5
RAM.
Disk speed
Second drive
THEN CPU
Get vista and you get to use RAM from a thumb drive to cache to. frees up RAM AND disk cycles for quicker everything.
RAM lots of it. Then get a second 7200 rpm (or greater) for the swap file. Booyah.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
grinchy
Apr 03, 2007 01:14 |  #6
get 4 gigs of ram to run memory hungry vista..and raid-0 some 150 raptors and WHAMMY..you got some real horsepower.
Body:
40D
Lenses:
Canon 50mm f/1.4
Canon 85mm f/1.8
Canon EF 24-105mm f/4
Misc:
580EX..Better Beamer..4 & 8gb Ridata 150X CF..Opteka Battery Grips..Kenko 1.4 TC..UV Filters..Lowepro Slingshot..Tripod
dpastern
Apr 03, 2007 01:43 |  #7
I'll disagree with the others - the Dual Cores will give you a LOT more grunt than your aging base CPU. The dual Cores (AMD 4200) that 2 other people are using in my household are at least 2.5x as fast as my AMD 3000+ CPU. You will NOT get that sort of speed increase from RAM. If you update, you're gonna have to trash the RAM anyways I'm pretty sure, since all the new boards only take DDR2 RAM (not DDR). Update the CPU (go an Intel dual core to be honest, they're way ahead of AMD at the moment in performance). Get a gb of DDR 2 RAM, you'll be happy :)
Dave
edit: My AMD 3000+ is probably 50-60% faster than your old AMD CPU. The Intel Dual cores are probably 10-15% faster than the AMD ones, so adding all of that up, you'll probably see a jump around 500% in performance imho.
NickSim87
Sir Chimp-a-lot
Apr 03, 2007 02:02 |  #8
Gotta disagree with Dave, I went from a single core AMD to a dual core AMD 3800+ and I saw little difference with photography related tasks. Another 1GB of RAM and it made a night and day difference!
Gear List | Feedback
dentharg
Apr 03, 2007 02:21 |  #9
It depends whether your RAW conversion software supports multicore.. I believe C1 doesn't currently :)
BibblePro got a serious boost generating prevs and whole processing when I switched from Athlon XP-2800 (2.1GHz) to Core2Duo E6300 (1.86GHz).
EOS 350D
Canon 17-40/4 | Canon 50/1.8 | Canon 85/1.8
580ex II | Velbon Sherpa 600R | WhiBal
tim
Light Bringer
Apr 03, 2007 02:44 |  #10
I got a huge speed boost during CS2 RAW conversion going from 3800+ to X2 4800+, bigger than from 1GB to 2GB of RAM, but it really depends what you do with your PC.
Ephemeral
Apr 03, 2007 03:28 as a reply to  @ tim's post |  #11
As stated. Unless the software you are using is optimised for multicore processors, RAM will make more of a difference.
Having the scratch disk in PS set to another drive will help to.
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | [COLOR=Silver]24-70mm L f/2.8 |[COLOR=Black] 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2
ephemeral.smugmug.com (external link)
zeddy
Apr 03, 2007 04:07 |  #12
Its probably ram, however a nice dual core processor should go along with it.
If you dont have enough ram youll be constantly paging and slowing the system down by using the hard drive to store data that needs to be in the ram rather than being paged into it.
Yet you want a faster processor to process all your images that are held in the ram. An interesting note here - i heard the inventor of Java do a talk the otherday (James Gosling) and he said that by the time im 40 machines will be around the 500 core mark. 500 cores could process those big images well :D
-Martin (flickr (external link))
Canon 30D, 24-70 f2.8L,
70-200 f2.8 IS L, Speedlite 430EX
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 03, 2007 09:51 |  #13
If it were RAM Vs. higher clock speeds, (and the clock speed difference wasn't like 300MHz Vs. 1.3Ghz! ) I'd say RAM,.
But RAM Vs. Dual core is a harder call.. as Dual core will be a tremendous boost to overall system performance and stability.
Still, for post processing id' say get RAM, and its certainly an easier upgrade too (and dude 1GB of RAM is only like $100.00
But really .. do both!
The jump to 2GB or even 3GB of RAM is a no brainer, it's easy and fast. Unfortunately after 3GB unless you have a 64bit OS, you can go no farther. This is when the CPU upgrade becomes the best and only step.
So grab some RAM and then look towards a Dual Core soon.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 03, 2007 09:54 |  #14
Ephemeral wrote in post #2976317 (external link)
PSCS is multi-core, as are most of the good RAW processors,. RSP, C1, Bibble, Lightroom, etc..
Breezebrowser is not, and I don't remember if Canon's own DPP is..
On top of that, one does NOT need to have multi core capable apps to take advantage of Dual core processors.
The OS is multi core capable and will be able to dole out CPU threads as needed,,. so even if you run an antiquated RAW processor that can only use one CPU, it will get 100% of that CPU while the OS kernal, and other peripheral stuff work on the other CPU.
I've got this great yet old laser printer,. it does all my text printing with aplomb. On any single core system it is installed on, when I print, the whole system locks up while it sends the print job to the laser.. I can only resume work when the printer driver lets me. Faster CPU and More ram have no effect on this other than to decrease the amount of downtime. Downtime of course is also dictated by the size of the job.
Printer spool grabs 100% CPU cycles,. period.
With Multicore, you don't even notice that you sent the 30 page print job,. I can keep on working with NO impact at all, however if I open task manager, I can clearly see that print spooling has taken 100% of ONE of the CPU cores to do the task, but left the other core/cores for me to keep working unhindered. this is just one example of how multicore works to your advantage even when (and in this case because) an app is only capable of working on a single core.
CDS' HOT LINKS
convergent
Gallery: 34 photos
Apr 03, 2007 09:57 |  #15
What's more important... your heart or your lungs? (sorry, couldn't resist)
I think you are going to be somewhat limited in what you can do. While your motherboard probably allows you to upgrade your memory, it most likely doesn't allow you to go to a DuoCore processor. Going from 1G to 2G of memory will definitely help your Photoshop performance... as will putting the scratch disk on a dedicated SATA drive. If you are consiering DuoCore, then I think thats a totally new everything since most of the DuoCore mobos require different memory from their predecessors.
Mike
R6 II - RF 100-500L f/4.5-7.1 IS - EF 17-40L f/4 - 24-70L f/2.8 II - 70-200L f/2.8 IS II -
135L f/2 - 100 f/2.8 Macro - Siggy 15 f/2.8 Fisheye - RF TC1.4 - EF TC1.4 II - TC2 III - (2) 600EX-RT - ST-E3-RT
7,550 views & 0 likes for this thread, 25 members have posted to it.
1093 guests, 119 members online
