Thread started 03 Apr 2007 (Tuesday) 21:41
580 EX AF beam not working with 20D
mmahoney
Apr 03, 2007 21:41 |  #1
The AF assist beam does not work on my 580EX when used with my 20D but it is fine with my 300D.
CF12 on the flash is set to "0", meaning AF assist beam is enabled and CF 05 on my camera (20D) is set to "2" meaning "Only ext. flash emits", (although I've tried 0 and 1 as well with no results). I've also tried all the camera bodys CF 04 functions thinking that the shutter button / AF controls may have something to do with it.
So unless I'm missing something that should get the beam to fire .. I've tried in all kinds of darkness, with lenses long & short, and with fresh batteries .. still no AF assist beam :mad:
Since it works with my 300D I can only think that the fault is with the 20D but maybe I'm missing something with the settings? Any suggestions?
Thanks,
Mike
Newfoundland Wedding Photographer (external link)
Curtis ­ N
Master Flasher
Apr 03, 2007 23:07 |  #2
Try switching your AF mode out of AI Servo.
mmahoney
Apr 04, 2007 04:49 |  #3
Curtis N wrote in post #2981488 (external link)
Curtis .. you've come to the rescue again, thanks.
Mike
DaveG
Joined Aug 2003
Apr 04, 2007 11:36 |  #4
mmahoney wrote in post #2981043 (external link)
Thanks,
Mike
Besides having it on AF-One Shot you need to have either the centre or ALL of the focusing rectagles enabled. If you just select one of the outside rectagles the flash assisted AF won't work. If you do have One Shot and the centre/all rectagles selected then the camera will focus in total darkness. For this I prefer just the centre rectagle as I think that it's more precise.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
Dellboy
Apr 04, 2007 11:40 |  #5
DaveG wrote in post #2983848 (external link)
Should work with any focus point, it does with mine.
PacAce
Joined Feb 2003
Apr 04, 2007 14:19 |  #6
You're probably thinking about the Sigma flash, Dave. I think that's how the Sigma 500 Super works with the more recent (versus older like 10D) EOS DSLR camera from what I recall reading here.
...Leo
DaveG
Joined Aug 2003
Apr 04, 2007 14:22 |  #7
Dellboy wrote in post #2983863 (external link)
I got this from Flash Photography with Canon EOS Cameras by NK Guy, http://photonotes.org …lash/index3.htm​l#afassist (external link) who is my reference source for all things Canon flash related.
He writes,"Also, if you have a camera body with multiple focusing points and your flash unit’s AF assist light isn’t lighting up in low light it’s probably because the AF light on the flash you happen to be using cannot cover your currently selected (ie: non-centre) focusing point. Many flash units have AF assist lights which can only illuminate the area around the central point."
I tested that with my 10D and it failed as predicted and I assumed that it was no different with my 20D or 5D.
Curtis ­ N
Master Flasher
Apr 04, 2007 14:39 |  #8
Dave, which flash unit are you using?
One of the selling points of the 580EX is that it covers all the focus points on a 1D Mk II. I believe the aforementioned article was originally written before the 580EX was introduced.
DaveG
Joined Aug 2003
Apr 04, 2007 14:45 |  #9
I use a 550
Curtis ­ N
Master Flasher
Apr 04, 2007 15:25 |  #10
Well that explains why your experience differs.
The Sigma Super is even worse. Center point only.
EOS ­ MAN1
Apr 05, 2007 15:50 |  #11
I had thatt same problem and it was in AI SERVO. Switched it and it was fine.
BERNARD BRZEZINSKI
- Photography & Consulting Services
- http://www.bernardbrze​zinski.comexternal link | contact: nfo@bernardbrzezinski.​com
Dellboy
Apr 06, 2007 09:36 |  #12
DaveG wrote in post #2984754 (external link)
I use a 550
If it's the 550ex that you have the auto focus assist should work on all focus points except the top and bottom one ( in landscape ). Try it for youself it should give you a few more options when out flashing.:lol:
1,603 views & 0 likes for this thread, 6 members have posted to it.
1764 guests, 104 members online
