Thread started 03 Apr 2007 (Tuesday) 23:51
Hoya so expensive because............
august23
Sensitive + Shopoholic = chick?
Apr 03, 2007 23:51 |  #1
Ok well I'm looking for a nice 82mm CPL to slap on my 16-35 MK II. The 3 obvious filter companies all have really different price ranges for what they all claim to be the same thing.
Super multicoated 82mm slim filters are:
Hoya: 320
B+W: 200
Heliopan: 167
Why is there such a price difference?
cdifoto
Don't get pissy with me
Apr 03, 2007 23:59 |  #2
Quality.
Kind of like Canon vs Sigma.
I find it a bit ironic that you have a $2800 camera body (on order) but are questioning the cost of a filter.
august23
Apr 04, 2007 00:10 |  #3
Once you make a huge purchase like that you start to think about the small things. :D
august23
Apr 04, 2007 00:14 |  #4
Any difference between the multicoated b+w filter and the kaesman b+W filter?
Tsmith
Formerly known as Bluedog_XT
Apr 04, 2007 00:16 as a reply to  @ august23's post |  #5
Hoya Pro 1 Digital 82mm Circular Polarizer PRO1D82CPL $171.11 @ www.2filter.com (external link)
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Apr 04, 2007 10:38 |  #6
august23 wrote in post #2981682 (external link)
Hoya: 320
B+W: 200
Heliopan: 167
I use Hoya SHMC Pro1 myself and yes good quality filters are expensive but I am surprised B+W and Heliopan are this much cheaper.
All three makes have two or more grades of filters, roughly equivalent types are:
Hoya SHMC or Pro1
B+W MRC
Heliopan SH-PMC
The B+W and Heliopan's without those letters are single coat filters and should be avoided.
Macrophotography by LordV
Lester ­ Wareham
Moderator
Best ofs: 5
Apr 04, 2007 10:41 |  #7
august23 wrote in post #2981781 (external link)
AFAIK the kaesman has sealed edges (polarisers have a polarising film between two sheets of optical glass).
May be worth paying for if you spend a lot of time in humid conditions. However, if you are in such conditions you should be keeping your kit in a dry box when not in use to stop fungi growing on the lenses etc.
cosworth
I'm comfortable with my masculinity
Apr 04, 2007 10:49 |  #8
B+W. I seem to killpolarizers fast and they have the best quality. They don't deleminate. My hoya is delaminating and my last hoya went cloudy. If this is indicative of their entire range, I'd not buy hoya again.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
jklewer
Apr 04, 2007 10:49 |  #9
For what I know, who knows! Pretty sure that the kaesman will provide you the finishing touches on weather sealing an EOS 1 package.
Gear
Lester ­ Wareham
Moderator
Best ofs: 5
Apr 04, 2007 12:17 |  #10
cosworth wrote in post #2983618 (external link)
God what do you do to them? :)
I have a 25 year old hoya polariser and it is just fine.
The B+W kaesman will be better for you, I can only assume you are using the filter in damp conditions or something.
I think it is a bit unfair to say this effects the whole of Hoya's range, only the polariser are laminated, all the others are solid hoya optical glass.
cosworth
Apr 04, 2007 12:20 |  #11
boats, sand, sun, surf, heat, cold. The usual. I have a number of polarizers and the ones that needed replacing were the Hoyas. My other ones are fine.
Not sure why. But yes the other filters are solid glass, I was just commenting on the possibility of this quality issue affecting other Hoya manufacturing processes. It's pretty hard to screw up a piece of threaded glass.
Lester ­ Wareham
Moderator
Best ofs: 5
Apr 04, 2007 12:41 |  #12
Thermal cycling could cause issues with any laminated structure in the end.
Is it the B+W kaesman you are using or just the bog standard B+W polariser?
I would not expect the standard B+W to be any better than the Hoya for sealing unless there is some process issue in the manufacture.
cosworth
Apr 04, 2007 12:51 |  #13
B+W Slim. Not the kaesemann.
Lester ­ Wareham
Moderator
Best ofs: 5
Apr 04, 2007 16:14 |  #14
Odd, what grade of Hoya BTW?
Double ­ Negative
*sniffles*
Apr 04, 2007 16:18 |  #15
With the 35L you'll save money at least. It's only 72mm. ;)
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
2,500 views & 0 likes for this thread, 7 members have posted to it.
904 guests, 117 members online
