Thread started 04 Apr 2007 (Wednesday) 18:15
Cant open a raw photo with CS2--Help
Pamela107
Joined Nov 2003
Apr 04, 2007 18:15 |  #1
I have a Raw file that I cant open in CS2.
When go I to open, and where the file is , it isnt highlighted as a readable file, if I pick all documents as a choice the file does high light.
After I click on the raw file, a window comes up called, Photoshop Raw OPtions,
when I click ok the photo opens and looks like this
see attachments
Why is this happening? This is the first time I will be using Raw from MY camera
I went to a friend s house and loaded one of her raw photos and it didnt do this, the photo was recognized with "all readable documents". And the photo opened open in a window for editing.
I cant figure this out. Im using a MacBook. And use a Sandisk card reader (all Jpegs dnload fine)
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
www.exposedimages.net (external link)
Pamela107
Joined Nov 2003
Apr 04, 2007 18:22 |  #2
For some reason the second one wont go through
Here is the other
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
vetkrazy
Apr 04, 2007 18:27 |  #3
Did you update CS2 for the latest plug in for the 30D?
Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
http://vetkrazy.exposu​remanager.com/ (external link)
Pamela107
Joined Nov 2003
Apr 04, 2007 18:31 as a reply to  @ vetkrazy's post |  #4
The photos are taken with a Rebel XT:)
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
Dachbean
Apr 04, 2007 19:00 as a reply to  @ Pamela107's post |  #5
Pamela,
Can you open any RAW files or is it just the one that won't open? I had this problem when I went I first got my 30D. I solved the problem by downloading the most recent updates. Check it out here:
http://www.adobe.com/d​ownloads/updates/ (external link)
I hope this helps
Todd
30D, 24-105 f4 L IS, 50 f1.8, Sig 10-20, 580 EX & 430EX
Pamela107
Joined Nov 2003
Apr 04, 2007 19:03 as a reply to  @ Dachbean's post |  #6
Only the raw photos I take with Rebel Xt, are the problem
The raw file s from a friends 20D opens fine .
Thankyou
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
Dachbean
Apr 04, 2007 19:12 |  #7
I would suggest that you download Camera Raw 3.6 and that should solve your problem.
I first had the XT and everything was fine, CS2 would read my XT RAW files. Then I bought my 30D and CS2 wouldn't read the 30D RAW files. Once I downloaded Camera Raw 3.6 everything ran smooth again.
Todd
CyberPet
Hiding Under a Rock
Apr 04, 2007 20:11 |  #8
Pamela, did you upgrade CS2 when it came out, as the first version didn't support the 350D/XT in the first verison of Camera Raw for CS2. You needed version 3.1 if I'm not mistaken. Now things have moved further on, so if you haven't upgraded your Camera Raw plugin since you installed CS2, it won't work.
Camera Raw 3.6 Macintosh version (external link)
Camera Raw 3.6 Windows version (external link)
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
Pamela107
Joined Nov 2003
Apr 04, 2007 20:13 as a reply to  @ CyberPet's post |  #9
Petra
I just downloaded the 3.7 for my CS2. I hope it was the right one.
It does work now. And I did save the old plugin , just in case.
Was I suppost to use 3.6?
Thankyou
Edit
I went to check on plugin info
the with in the name - it says powerpc file- is this the correct plugin name for mac? This is listed under the work kind.
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
CyberPet
Hiding Under a Rock
Apr 04, 2007 20:57 |  #10
Ah, didn't know there was a newer version than 3.6. No, you keep 3.7 and if it works, then all the better! :D
/Petra Hall
2,046 views & 0 likes for this thread, 4 members have posted to it.
1269 guests, 121 members online
