Thread started 06 Apr 2007 (Friday) 23:00
Lets see pictures of the Tokina 10-17mm Fisheye!
cjm
Gallery: 11 photos
Apr 06, 2007 23:00 |  #1
I am on the fence wondering if I should even bother with the Tokina AT-X 10-17mm F 3.5-4.5 DX Fish-Eye lens. I have read the quality seems to be pretty good so I am looking for POTN users with this lens to show me their examples why I should buy this glass.
Christopher J. Martin
imagesbychristopher.co​m (external link)
Raphael ­ Emond
Apr 06, 2007 23:59 |  #2
I like to know too!
Canon Rebel XT, BG-E3, Sigma 12-24 EX DG HSM, 28/2.8, 50/1.8, 24-105L IS USM, Sigma 70-200 2.8 EX DG HSM
420EX, Sigma 1.4X Converter, Moded Off-Shoe Cord 2, 2x1Gb + 1x2Gb, Pelican 1550 Case, Hoya IR72, Mono-Tripod.
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Apr 07, 2007 00:14 |  #3
You know, I've briefly tried out the Tokina 10-17 and the Pentax 10-17 and compared to a 10mm end of the ultrawide, it's not much wider and the distortion limits its diversity.
Seeing as you already have a 10-22, I'm not sure it's worth it. I was thinking about trading in the 10-20 for it, but after trying it out, I gave up on that idea.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Madweasel
Apr 07, 2007 07:33 |  #4
The corner-to-corner angular field of rectilinear and fish-eye 10mm lenses on a 1.6x crop body is 108 and 180 degrees respectively. That seems quite a big difference to me. You have to decide for yourself about the acceptability of the curvilinear distortion though.
Mark.
wimg
Apr 07, 2007 08:00 |  #5
Hi Tee Why,
Tee Why wrote in post #2998941 (external link)
I'm sorry, but I respectfully disagree. There is a tremendous difference between the two - I have both. The 10 mm on the 10-22 rectilinear zoom has an AoV, diagonally, of 107.5 degrees, the Tokina 10-17 fisheye zoom gets to 180 degrees diagonal, plus, it has a fisheye type projection.
Just compare the two following pictures, first the Tokina, at 10 mm, closest focusing distance:
And here is the 10-22 at 10 mm:
As you can see there si quite a difference in AoV, and in distortion. The wings and body of the plane are still shown at the correct angles, while the pergola parts in the top of the fisheye picture, although they are at right angles, are totally bent.
BTW, the flare and ghosting in the plane pic was deliberate; this has become a lot less now I uses B&W MRC filters rather than Canon UV Sharp Cut filters, although the effect was deliberate here, and in the fisheye pic the front of the flower was actually touching the front element of the lens!
Kind regards, Wim
circa
Apr 07, 2007 09:28 as a reply to  @ wimg's post |  #6
wonderful skateboard adventures:
http://www.flickr.com/​photos/wjphoto/ (external link)
www.fotophun.blogspot.​com (external link)
killerbab
Apr 07, 2007 10:44 |  #7
Here is a similar thread.
https://photography-on-the.net …22&highlight=to​kina+10-17
i want one bad.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Apr 07, 2007 10:59 |  #8
wimg wrote in post #2999842 (external link)
Hi Tee Why,
Kind regards, Wim
Kind of hard to tell anything with 2 such different shots. I would really like to see this comparison done with both at 10 mm, same f stop, and same subject.
Doc Klepper in the USA
I
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Apr 07, 2007 11:45 |  #9
Wimg,
I don't disagree with you at all. The fisheye is a different beast than an ultrawide zoom. I've had a Sigma 15mm on a 1DMII for a while myself. To me, it's a specialty lens for specific shots. I generally don't think of fisheyes being interchangable to an ultrawide.
I'm just not sure it's worth $570 or so to me, that's all.
My buddy was nice enough to take some similar shots for comparison with his Pentax 10-17fish vs a sigma 10-20.
Take a look here.
http://www.pbase.com/a​linla/1017_vs_1020 (external link)
for taking landscape shots, the distortion bothers me, for taking trick shots where distortion is used for dramatic effects, the fisheye is very unique.
Madweasel
Apr 07, 2007 14:12 |  #10
I think the reason some people are surprised there is not more difference is that all the difference (apart from the distortion) is at the corners. Because both are 10mm, the central part of the image is actually exactly the same.
Mark.
wimg
Apr 07, 2007 16:55 |  #11
Hi Doc,
rklepper wrote in post #3000476 (external link)
The idea was to show the difference in projection; the straight lines with the UWA vs the bent lines with the fisheye, plus the much wider viewing angle.
I'll try to make a few comparison shots in the next few days ahead; same subject, same distance :).
Kind regards, Wim
wimg
Apr 07, 2007 16:57 |  #12
Hi Mark,
Madweasel wrote in post #3001218 (external link)
No, it isn't. Everything is distorted with a fisheye. Just at first glance the center may look the same.
Kind regards, Wim
wimg
Apr 07, 2007 17:10 |  #13
Hi Tee Why,
Tee Why wrote in post #3000659 (external link)
Wimg,
Well, if you need a fisheye, there is not a lot of choice, certainly not for APS-C. I don't particularly like to crop the black corners from a circular FF fisheye, I'd rather have a proper 180 degrees diagonally. And it so happens that the Tokina is a great choice, IMO, for all formats.
Take a look here.
Thank you for sharing that link, it makes the differences much easier to see than they are in my sample shots.
I'll try to do a few defishes in the next few weeks, and share them here. With a fisheye shot defished, you get the widest rectilinear shots possible with any lens :), with relatively little vignetting.
Kind regards, Wim
Lani ­ Kai
"blissfully unaware"
Apr 08, 2007 03:17 |  #14
You want to see pictures of the lens? :D
Anyway, here's one taken with a 1D Mark II at 12mm:
IMAGE: http://img244.imageshack.us/img244/3453/nn4d2290dj2.jpg
Wide open the sharpness isn't anything to write home about but stopped down past about f/5.6 it's tack sharp. On a 1D Mark II there's no vignetting from 12mm to 17mm. I didn't see any vignetting in the viewfinder but apparently I didn't zoom in far enough for this one. I'd crop but then I'd lose the EXIF for interested parties
Website (external link) | Facebook (external link) | Equipment list
SHULTSIE!!!
"Stonehenge wasn't too impressive"
Apr 14, 2007 17:22 |  #15
Here's a landscape of the Washington Monument from the WWII memorial with the Toki10-17. I just bought this lens a few days ago... I like it, but I don't see the pactically of having this as your sole UWA lens. I was contemplating on exchanging this with the 10-20, but I think having both in the bag would be better. Can't always use the FE for wide shots...
Another thing to add... I did get a little wider @ the 10mm range with the Toki vs the Canon.
IMAGE: http://i35.photobucket.com/albums/d179/piflyboy/IMG_0406.jpg
Justin
My 15 minutes of fame... (external link)
3,463 views & 0 likes for this thread, 10 members have posted to it.
1320 guests, 135 members online
