Thread started 07 Apr 2007 (Saturday) 00:18
Need Help with Ilford Profiles
Cyclone_S
Apr 07, 2007 00:18 |  #1
I just got a Canon 6700D and I'm trying it out on some Ilford Paper(Smooth Pearl Paper and Smooth Heavyweight Matte Paper).
I followed the instructions that came with the profiles I downloaded but when I print using the Ilfrod profiles everything is so dark and you lose a lot of detail. it looks horrible.
The print preview window looks basically the same as what comes out but what is printed is even more saturated! I tried adjusting the contrast and intensity in the printer driver but it still looks horrible.
anyone know what i'm doing wrong? Thank you.
My Portfolio
http://www.inspiredvis​uals.com (external link)
René ­ Damkot
Apr 07, 2007 04:22 |  #2
Have a read here: Click. (external link)
If that doesn't work, some extra info about settings might be nice.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Cyclone_S
Apr 07, 2007 15:02 as a reply to  @ René Damkot's post |  #3
I read the link and it seems to make sense to me but it didn't explain why the canon print preview and prints turn out very black looking. Here are my Photoshop Colour settings.
I selected 'other photo paper' for the Ilford Smooth Heavy Matte and 'Photo Paper Plus Glossy' for the Smooth Pearl paper and both ICC profiles seem to give me the same problem. In the printer drivr settings I clicked Manual and selected non for colour correction.
Grrr this is so confusing.
My Portfolio
Cyclone_S
Apr 07, 2007 19:34 as a reply to  @ Cyclone_S's post |  #4
well I did some more searching and reading here on the forums but for the life of me I don't know what I am doing wrong. If I use srgb in photoshop all the images look washed out on my monitor and not the same as i see them in IE or the windows image/fax viewer.
I did however find a way to print with results i'm happy with but everything I read about colour manegment says i'm doing it wrong.
I have the colour management set to "Monitor RGB - Color Profile for Windows" in the color setting and told photoshop to use this profile in the print settings. The photos that print out with this configuration look pretty close to what I see on my monitor.
Still like to figure out what i'm doing wrong though. help apreciated. thanks.
My Portfolio
jej826
Apr 07, 2007 22:15 |  #5
Cyclone_S wrote in post #3002621 (external link)
It seems we are having the same problem. My prints and the image in print with preview are over saturated.I can get mine to print more accurate using "printer color managment" in the printer profile.
I am using a Canon i9900 and Elements 4.
Jim
Canon 20D, Canon 50 f/1.8, Canon 18-55 f/4-5.6 USM, Canon 70-200 f/2.8L, Canon 85 f/1.8, POTN neckstrap
PacAce
Joined Feb 2003
Apr 07, 2007 22:57 |  #6
You really shouldn't be using your monitor profile as your working color space. You should be using sRGB, Adobe RGB or one of the other device independent color spaces for your working space.
Is your monitor calibrated and profiled? If not, that may be your problem.
...Leo
René ­ Damkot
Apr 07, 2007 22:58 |  #7
For starters: Do not use your monitor profile as a working space...
Cyclone_S
Apr 08, 2007 15:05 as a reply to  @ René Damkot's post |  #8
I'm not really sure. When I first set up my monitor I adjusted the colour etc manually. I have both a LCD and CRT and both are totally different monitors and both give me the same problem.
When I use sRGB or Adobe RGB all photos that I open up in PS look very light and shadow areas reveal more grain. Even photos directly from my camera which have sRGB profiles look too light and washed out.
If I use sRGB as a working space the photos look very light in photoshop but if I use the 'Print Preview' and set it to use the sRGB print profile then the Canon Print Preview window shows the photo with colours looking like I see them In Internet explorer and don't look too light. But when I use the sRGB working space and then use the ilford print profiles I still get very black and oversaturated colours.
this makes no sense lol. Anyone willing to walk me through this? I want this photo to print out the same(close) to what I see on my desktop or internet explorer etc using the ilford profiles.
original file(not mine)
http://www.inspiredvis​uals.com/egggray-1148078904.jpg (external link)
If it helps I could take some photos of the actual prints that come out. thanks
My Portfolio
René ­ Damkot
Apr 09, 2007 06:06 |  #9
Looks fine in my (color managed) browser.
Check the second link I provided: There are a few links in there to printing. (first link I gave is a direct link).
Try those settings, and see what happens.
Cyclone_S
Apr 09, 2007 20:45 as a reply to  @ René Damkot's post |  #10
ok for some reason photoshop is acting weird and won't switch the colour space...
so I am using Digital Photo Professional. When I open a raw file and switch from sRGB to Adobe RGB the colours look a bit brighter. Is this normal? When I open a sRGB jpeg photo and switch to Adobe RGB the colours look a bit darker. Is this normal to? I still have the black saturated colours in DPP like I did in photoshop in the print preview window using the ilford profiles.
I read your tut twice thanks. It makes sense. I will read those links also and try to learn a bit more. This is so confusing. The idea of colour spaces isn't confusing but I am getting so many conflicting results that it makes no logical sense to me...
My Portfolio
René ­ Damkot
Apr 10, 2007 01:31 |  #11
You say you "switch color spaces". Do you mean you "convert" or "assign"? The first shouldn't give (big) a difference (depending on the colors in the image and the rendering intent used; see some of the links in the link in post #7).
I think in DPP the image should look the same regardless of output space. (I think that's what you mean?).
Assigning an AdobeRGB profile to an sRGB file (and vice versa)in PS essentially throws color management out, and will give a big color shift.
cosworth
I'm comfortable with my masculinity
Apr 10, 2007 01:41 |  #12
After all the colour space stuff gets worked out, go back to the .zip file that you got from ilford and read the PDF supplied to show you exactly how to setup the print settings. They are key.
FYI: Costco Kirkland Premium Glossy Photo Paper is made by ilford and if you use the Smooth Gloss profile it works excellent.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
Cyclone_S
Apr 10, 2007 14:22 |  #13
René Damkot wrote in post #3014911 (external link)
In DPP I went to Adjustment/Work Color Space and changed it from sRGB to Adobe RGB while viewing a raw file. The picture looked lighter then the sRGB. When I used the Wide Color Gamut RGB the picture looked a lot lighter. The lighter the colours look the more grain I see in the shadow areas. I'm usuming this is normal?
In photoshop however when I use the sRGB working space a jpeg photo with a sRGB profile embedded or any photo for that matter looks very light. Maybe something is messed up on my computer?
I will read those links when I get the chance and hopfully theres a solution in there. :)
That's cool. Thanks. I bet its cheaper to :)
My Portfolio
Zwiz
Joined Jul 2004
Apr 10, 2007 16:13 as a reply to  @ Cyclone_S's post |  #14
To print correctly with Photoshop, you really need to have a calibrated monitor. Otherwise, you will end up like you're doing right now (and what I've done in the past); playing randomly with settings until you have something <<ok>>! When you have a calibrated monitor, you will want Photoshop to operate with either the sRGB or Adobe RGB color space and your images will be display correctly. The funny thing is that a sRGB image in Photoshop will not look the same in a browser likle Explorer (no color management). But with a calibrated monitor, it should be very close. The whole point of the sRGB profile is to have a color space which is close to what will be display by an "average" monitor/video card combo. When you play with color management and ICC profiles, you really need to take care of the whole system (from the monitor to the printer).
XT/XTi/40D, 10-22mm, 300mm f/4L IS, 100-400mm L IS, 430EX II.
Gallery: http://picasaweb.googl​e.com/blubOmatic (external link)
René ­ Damkot
Apr 11, 2007 06:06 |  #15
Cyclone_S wrote in post #3017630 (external link)
What version of DPP are you using?
I tried it out, (because I never use the Adjustment > Work Color Space option, I set a default work space in the prefs), and found a few things:
sRGB (as well as Apple RGB and ColorMatch RGB) is displayed a bit lighter then AdobeRGB, or Wide Gamut RGB(which appears a *tiny* bit darker still...)
These are *small* differences over here.
When using AdobeRGB (my default work space), and exporting a jpg, the jpg looks a tiny bit different in PSCS2. (a bit lighter/less contrast / tiny bit less red/more green).
The same goes for Wide GamutRGB and sRGB.
(You need to have the screenshots side by side to see the difference between DPP and PS though.)
The sRGB jpg looks a bit less saturated in PS then the other files. (I think I see a very small difference between the Wide GamutRGB (16bpc tif) and AdobeRGB (jpg) file color/contrast wise.). The difference between the working spaces seem about the same in both programs.
(for those interested: Here is a screenshot of the sRGB and WideGamutRGB screenshot opened in PS. (screenshot converted to sRGB)
Click image to get a layerer (4,7Mb) PSD file with screenshots of all three working spaces in both programs, as well as a screenshot of the Gamut warning)
On my system, there seems to be a small difference between PSCS2 and DPP on the one hand. I think this is *not as it should be*: One of the programs (DPP?) doesn't color manage quite as it should. (I never noticed this difference before updating to DPP 3.0.0. I'll have to see if I can find an older version and try again.)
Edit: Re-installed DPP 2223, and it behaves the same.
The sRGB file is displayed a bit lighter / less contrasty / saturated.
I think this is because the colors availiable in sRGB are not as 'deep' as availiable in WideGamutRGB.
The file I was using for this comparison gave quite a Gamut warning when going from WideGamutRGB to sRGB, so that might explain some differences between those working spaces. Since the display can't display all the colors of the wider working spaces, a 'translation' is made by the monitor profile. That may be 'translating' deeper colors to 'darker'... I was surprised the difference was affecting the darker, seemingly neutral colors, as much as it did though.
If you are seeing *huge* differences, something is not quite right.
If the file looks *lighter* in DPP in AdobeRGB, I can't explain that either...
If anyone has a better explanation, I'm all ears...
2,537 views & 0 likes for this thread, 7 members have posted to it.
2814 guests, 164 members online
