Hello, I am new to the forums. I have a question. Why would sensor dust show up at the higher apertures but not the lower ones. I have tried this over 10 times with 10 different backgrounds (mostly different shots of the sky) and get the same result each time. 100mm, f4.5, no specs on my image. 100mm, f20, the same 5 specs on my image, in the same place every time!! I have tried this multiple times with both my Canon 100mm 2.8 macro and Canon 28-135 is usm (at 100mm) and the spots are in the same place so I know it is not the lens...
Also, how can I clean the sensor? I have done exactly what the manual says at least 25 times. The dust went from about 12 good specs down to 5 but those 5 will not go away no matter how hard I blow. I am a newb so sorry for the simplistic question...
thanks, andy
