Thread started 09 Apr 2007 (Monday) 00:25
Oops I might have scratched my sensor!
samsen
Apr 09, 2007 00:25 |  #1
I have a horizontal line that is persisting on the sensor filter, visible on low F stop images very sharply (Needless to say in a very distracting way).
What should I do?
Has anyone had this boo boo before? Will Canon or local camera shop, replace the IR sensor fitler for a reasonable fee? Do I have any other options:o
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
thekid24
pro-zack-lee
Apr 09, 2007 00:26 |  #2
Im curious as to how it was scratched
Adaptive
don't defend yourself, call modday
Apr 09, 2007 00:31 |  #3
I'm also curious to find out how someone can make a "boo boo" like this!!!
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Apr 09, 2007 00:32 |  #4
Did you do anything which may have led to it being scratched?
Post an example?
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
samsen
Apr 09, 2007 00:42 |  #5
Dry cleaning method.
Usually had no problem. Guess the lens cleaning paper was pierced by the cleaning wand.
I am ashamed enough please don't make me feel more miserables, I need a clue as to what to do and not .....:o
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
icestrike
Apr 09, 2007 00:46 as a reply to  @ samsen's post |  #6
able to post a sample affected pic?
take it easy
sometimes i DIY on cleanin the sensor, and din do a good job, able to see some visible marks on the sensor
i will then usually bring it immediately to canon service centre to clean up my mess. :D
so far is been alright for me after that visit.
my own:works (external link)
5D mk3| 1D mk X | 600D | 16-35F2.8 MK II L | 24-70F2.8 MK II L | 70-200F2.8IS L | 24F1.4 MK II L | 35F1.4 L | 50F1.2 L | 40mm F2.8 | 100macroF2.8IS L | 8-15F2.8 Fisheye L | 24F3.2 Mk I tilt-shift L | 580exmk2 & 600ex-RT | Elinchrom Quadra |
chengvc
Apr 09, 2007 00:47 |  #7
Don't be scare.....
There is nothing more to do with that scratched line.....
Go to photographic store to buy a bottole of lens cleaning liquid.....
Change the dry method in to wet cleaning method.....
Some time when I use dry cleaning......
It will make a line out too.....
But after using wet....
The line have gone!!!
Chengvc
icestrike
Apr 09, 2007 00:55 |  #8
chengvc wrote in post #3008809 (external link)
Don't be scare.....
Chengvc
Yup yup agree with you !
if i am not wrong there is a sort of plastic layer above the sensor ?
or maybe i am wrong? hmm
samsen
Apr 09, 2007 01:00 |  #9
Here is an example.
I have over sharpen the image to see the lines that are marked by flash. Other points are garden variety dirt and are cleaned later on. If you don't see the scratches clearly or in hallo form there is a good reason.
I got eclipse but not yet applied. Doubt if that can clean scratch either.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
chengvc
Apr 09, 2007 01:01 |  #10
I don't think there is a plastic layer......
I think that is a Glass layer.....
With a very thin coated oxide layer or some compound......
That layer is hard.....
chengvc
Apr 09, 2007 01:03 |  #11
That line >MIGHT< be dirt that pushed by the edge of the sensor cleaning tools.....
I've be thinking some time the line might be the edge of the sensor cleaning tools.....
That dirt have be push to there!!!
samsen
Apr 09, 2007 01:08 |  #12
I have cleaned it several times (Dry). Everything is variable except the lines with twisted head that persist.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
saravrose
"I quit smoking dope"
Apr 09, 2007 01:10 |  #13
take it into a shop maybe or to Canon to have serviced..
Canon 30D BG_E2 Grip Rebel XT BG-E3 battery grip
Canon 50mm f1.8 Tamron 17-50 f2.8
Canon 70-200f4.0L 100-400L aka (Chuck)
a couple of bags and a lot of big ideas
"The shot is in my head before it's in front of my camera...."
chengvc
Apr 09, 2007 01:12 |  #14
Samsen.....
Asually....
If I am you......
I will try wet clean method for that line ASAP.....
There are two reason.....
1)As soon you try....
Then you will know whats happening.....
2)No need to be scare.....
(Sorry I might be mean......)
samsen
Apr 09, 2007 01:30 |  #15
Thanks everyone.
Will use that eclipse and will post the result soon.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
4,372 views & 0 likes for this thread, 17 members have posted to it.
1347 guests, 136 members online
