dpanicc1 wrote:
RE: Stroboframe Pro-T
That's a bummer. I tried to order an anti-twist bracket on B&H's website but wasn't sure which one to order. I called Tiffen (Stroboframe too I guess) and she said they only make the anti-twist bracket for the camera WITHOUT the vertical grip and that the cork would suffice. The cork really doesn't do a good job.
Any comments or ideas?
TIA,
Dan
I use the Pro-T and my anti-twist plate has 35-H stamped on it, so one exists despite what the idiot at Tiffen told you. The cork DOES NOT suffice and if you use the bracket without the metal anti-twist plate you won't use it more than once.
This 35-H ATP is for the 10D with the vertical grip and I just want to make this clear. For the other writer the 550EX flash has more than enough weight to require the metal ATP; and as far as that goes, I would be concerned even with the weight of the smaller 420EX.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
