Thread started 19 Apr 2004 (Monday) 17:46
Why doesn't 4x6 = 4x6
Gibmeister
Joined Apr 2003
Apr 19, 2004 17:46 |  #1
I have a Canon S9000 printer and I use Photoshop 7 to size my photos for printing. I use the crop tool set at 4x6 at 300dpi, but when I go to print and tell the printer to do borderless prints on Canon 4x6 "Photo Paper Plus Glossy" paper I am told that the document will slightly extend off the paper. Portions of the photo are cut off in the process. Has anyone experience this and is there a way to get the whole print to come out. I tried the "fit to page" setting and that did not help. Thanks
Gib
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Apr 19, 2004 18:11 |  #2
I've had the samething happen but couldn't figure out how to fix it (other than printing 4x6 on 5x7 paper).
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
Guillermo ­ Freige
Joined Jun 2003
Apr 19, 2004 19:11 |  #3
My epson photo 820 has the same problem. I must use something like a 3.8x5.7 size for an actual 4x6 borderless picture, but if I use the Epson 777 (no borderless option here), the 4x6 size works just fine. I'm using PS CS
Guillermo
EOS 5D MkII, 40D and 20D owner.
EF 17-40L, 24-105L IS , 70-300 IS, 24 f2.8, 35 f2, 50 f2.5 Macro, 85 f1.8.
EF-s 18-55 IS. Sigma 12-24, Tamron 17-50 Di II
dicky109
Joined Feb 2003
Apr 19, 2004 23:14 |  #4
Don't know if this will apply in your situations, however, I had this problem when I first started using my Epson 1280, but realized that I was choosing borderless on 4 x 6 paper with perforated edges. Since the paper is actually larger than 4 x 6, if you choose borderless, it creates a sizing problem. I unchecked the "borderless" option, & it printed the full size.
Alternatively, the easiest solution is to buy the "no perforation" paper and then print borderless.
Rich B
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt"--Bertrand Russell
Gibmeister
Joined Apr 2003
Apr 20, 2004 04:15 |  #5
Thanks, I am using the "no perforation" Canon paper. I might try the suggestion to resize the photo to a smaller than 4x6 size, but it seems I shouldn't have to do that.
dtrayers
Joined Mar 2003
Apr 20, 2004 06:20 |  #6
I have a Canon S820 (similar to the S9000) and I print 4x6 without any issues.
I crop to a 4x6 size. I don't specify the resolution, it usually results to well over 240 ppi. I select the paper size to 4x6 in the printer and set the bleed to the third tick in the printer settings.
Here's a screen shot of my printer setup:
IMAGE: http://home.comcast.net/~dtrayers/photos/4x6.jpg
You can control the amount of bleed by the extension control.
I print on Epson Premium 4x6 paper.
-Dave
http://www.trayersphot​ography.com (external link)
Gibmeister
Joined Apr 2003
Apr 20, 2004 07:34 |  #7
Thanks Dave I will give this a try when I get home from work and report back with my results.
Gibmeister
Joined Apr 2003
Apr 25, 2004 09:33 |  #8
Thanks for the suggestions. The one that worked the best for me is to size the pictures at 3.88" by 5.85". I have not fine tuned it yet but this seems to work pretty good.
3,716 views & 0 likes for this thread, 5 members have posted to it.
1742 guests, 148 members online
