Thread started 15 Apr 2007 (Sunday) 15:38
Using 2IS zoom - getting lack of definition
timc
Gallery: 146 photos
Apr 15, 2007 15:38 |  #1
I've been taking bird pictures with my 2IS zoom to the max and haven't been getting good definition in the pictures. I've been shooting at ISO 100 and 400, 1000-1250 speed and AV setting or manual. The weather has been cloudy, maybe that's an issue. Any advice would be appreciated.
Thanks.
Jon
Joined Jun 2004
Apr 15, 2007 16:10 |  #2
How are you setting exposure? Can you maybe post an example or two of what you consider not "getting good definition"?
Jon
Cocker Spaniels
SaNdMaN82
Apr 15, 2007 20:02 as a reply to  @ Jon's post |  #3
yes, i don't know what you mean by "good definition". Are the pictures blurry?, out of focus?, grainny?. A whole set of things could be happening.
Something i've noticed, is that you said that the zoom was to the max... are you using the digital zoom?. Because if so, the quality of the picture will be affected big time (also notice, that the size of a pic at 48x combined zoom, is about 1/2 - 1/4 of a 12x picture).
But, to clear things out, you should really post a few samples ;)
Greetings,
Canon S2 IS
pescare
Apr 16, 2007 00:18 as a reply to  @ SaNdMaN82's post |  #4
Hand-held or tripod? IS mode on?
timc
Gallery: 146 photos
Apr 16, 2007 11:37 |  #5
I've posted a sample of the bird pictures that don't seem too well defined. Any advice would be appreciated.
Thanks.
IMAGE: http://i82.photobucket.com/albums/j249/timjc/BlueJay4.jpg
Jon
Joined Jun 2004
Apr 16, 2007 11:42 |  #6
They block Photobucket at work. Anyone else care to comment? I'll try to check this evening.
Jon
Cocker Spaniels
timc
Gallery: 146 photos
Apr 16, 2007 11:44 |  #7
This was hand held. What is the IS mode? I'm not sure what that is?
pescare
Apr 16, 2007 12:04 as a reply to  @ timc's post |  #8
Really, I don't think there is anything out of the ordinary in that shot. Given the conditions and the fact that you were shooting hand-held at 432mm, that's not bad.
IS is Image Stabilization. A function available on that camera that diminishes camera shake on shots like this. Do some test shots with IS turned on, and with the camera on a tripod or solid surface and see what you get.
SaNdMaN82
Apr 16, 2007 12:37 as a reply to  @ pescare's post |  #9
It's not that bad. Yes, it's a bit (just a bit) soft, but you have to consider that the bird was pretty cover by branches, and it's not an ideal situation for auto focus.
i have 2 dif readings regarding the shutter speed... i've seen 1/6 and 1/1600... i don't think the real one is 1/1600, if it was a cloudy day, i don't know if you could achieve that speed.
The other thing you should try, is setting the IS mode to "shoot only", and try again with the object in the clear. Again, that bird was among branches, and sometimes the AF just don't focus on what you'd think it would. Use spot metering as well.
PS: jon, here is the picture @ imageshack
Greetings,
Canon S2 IS
JustShootin'
Apr 16, 2007 13:07 as a reply to  @ SaNdMaN82's post |  #10
It's a busy picture, but I believe with spot metering, the bird would have been in much sharper focus, providing the camera was steadied properly.
Gary
Canon SX40, S100 and a Non Canon dSLR
“Any darn fool can make something complex;
it takes a genius to make something simple.”—Pete Seeger
timc
Gallery: 146 photos
Apr 16, 2007 13:14 |  #11
Thanks for the comments the 2nd version. I double checked my zoombrowser and I shot at 1/1600 4.0 which I tend to use for birds. I think the IS was on as there was an camera icon surrounded by hands. Maybe I should try manual focus with the surroundings of branches. I did have it on AF and tried to put the bird's head in the box. I guess if I were able to shoot at f8.0 it would have been an optimal setting for clarity.
Jon
Joined Jun 2004
Apr 16, 2007 18:25 |  #12
Like Gary said, it's kind of busy - that may have thrown off the focus a bit. And with the bright sky background the Jay's edges may have gotten spill-over, throwing off things as well. But not "spot metering" so much as selecting the AF point. There's some purple fringing which you can expect in a contrasty situation like that, with even the best of lenses. It's a digital thing.
Jon
Cocker Spaniels
timc
Gallery: 146 photos
Apr 17, 2007 07:43 as a reply to  @ Jon's post |  #13
Thanks for your comments, I'll keep trying to get it better...
beeGjay
Apr 17, 2007 15:33 |  #14
I suppose it could be improved in post processing software in some ways but I think for being a new camera owner your shot is terrific. My S3 is not new but I would be happy with that although I would crop to the bird some to eliminate such a busy background.
Bernie
Canon-S3IS
2,659 views & 0 likes for this thread, 6 members have posted to it.
1392 guests, 136 members online
