Thread started 15 Apr 2007 (Sunday) 21:59
28-135 mm Canon
trek ­ 9.8
Apr 15, 2007 21:59 |  #1
What's going on with this lens? Everybody I talked to love the lens.
It cost around $ 500 has no wide angle to speak of and isn't very fast, f 4.
Unless the 52 diameter lens allows more light in Vs my 18-55 mm F 3.5.
Trek 9.8
twotimer
Apr 15, 2007 22:05 |  #2
There is more to a lens than speed, I imagine this lens will appeal to people that want more reach and aren't that concerned with the wide end. The kit lens is 1/2 a stop faster at the wide end but it is very quickly a full stop slower at f5.6.
Gerhard
JohnJ80
Apr 15, 2007 22:26 |  #3
Well, it shouldn't cost that much, i think they can be had for $389 or so. $500 is too much.
I find it to be a rather mediocre lens - not good, not bad and not great.
Softish, contrast could be better, color sat could be better, lots of CA around edges. build quality is not so great either. Overall, pretty mediocre.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
BEEEsH
Apr 15, 2007 22:29 |  #4
I found it to be a mediocre lens. I bought it a few days ago, put it through its paces and then brought it back. I didn't find it to be very sharp up to F8. We are talking about the IS USM right?
EOS 5D MK II
16-35mm F2.8L II - 24-105mm F4L - 35mm F1.4L - 85mm F1.2L II - 70-300 IS -
580EX II - MANFROTTO 055D w/RC 141 - DOMKE F3X - Nanuk 940 White
asysin2leads
I'm kissing arse
Apr 15, 2007 23:12 as a reply to  @ BEEEsH's post |  #5
I bought this lens when I bought my camera. I love it. It is actually a f/3.5. I've used this lens to shoot sports, portraits and various others. I love it. You can't beat this lens for $389. Ok, sometimes it can focus a tad slow in low light, but I've still had good luck with it. This is my walk-around lens and am extremely happy with it.
Kevin
https://www.google.com ….com&ctz=Americ​a/New_York (external link)
ItsMike
Apr 15, 2007 23:56 |  #6
I got this lens about 4 weeks ago and it has not left my camera as of yet ( Even over my 70-200mm) ... The IQ is fine, The IS is worth its weight in gold...
Gear
EORI
Apr 16, 2007 00:13 |  #7
trek 9.8 wrote in post #3048068 (external link)
A wider filter diameter (which I believe is 58mm on the 28-135) does not necessarily translate to more light. For example, my 50mm 1.8 with 52mm filter diameter is several stops faster than this zoom.
As for your beef about lack of wide angle, this lens was originally designed to be used on film cameras, and not on digital crop cameras. When it debuted in the late '90s, it was considered the ultimate all-in-one consumer zoom, both for the available zoom range, IS (still novel then), and relatively good IQ. I had its predecessor lens, the 35-135, and enjoyed using it.
The digital crop equivalent with a range similar to the 28-135IS is the 17-85IS. It's not an L lens, but is a decent consumer zoom with the desirable IS.
johnstoy
Apr 16, 2007 00:13 |  #8
I own the 24-70mm 2.8L and the 70-200mm 2.8L IS and find that the 28-135mm IS is also a fantastic lens...
It's a 72MM wide lens... The other "L's" I own are 77mm wide...
For low light photography, I presently use my 50mm 1.4 and 85mm 1.8... other wise, I find that the 28-135 IS is a great return for the money... the IS is great... the Macro capabilities are truly rewarding... The USM focuses quickly... Even the build is pretty good...
Maybe there is the occasional "bad" copy out there... If so, send it to Canon for calibration or return it for a different copy... for the small price, it's unbeatable...
John Stoy
www.poconophotos.com (external link)
My Gear List
"Are you only Looking or actually Seeing", from Microbiology 101.
45R
Joined Jun 2004
Apr 16, 2007 00:22 |  #9
I cut my teeth with the 28-135. I also happen to own the 70-200L F2.8 and use the 28-135 for 95% of my shooting. I find it a superb lens for the money.
Canon 7D, Canon 30D, Canon 580EX,28-135mm IS USM
50mm F1.8,15mm F2.8,18-55mm Kit lens
17-40L,70-200LF2.8 IS, 2X TC
orisky
Apr 16, 2007 00:28 |  #10
I found it to be a decently good lens and what I used as my first walkaround. I replaced it about 5 months back with a 24-105L and I'm not looking back. Sharper, better color, contrast... but also over twice as expensive.
YosemiteJunkie
Apr 16, 2007 01:35 |  #11
Once Igot it calibrated it stays on the camera at least 75% of the time. It's worked out great for me.
Happy Shooting, Herb
Canon 5D, 20D w/ BG-E2 Grip, Rebel 35mm, 580EX II Flash, 420EX Flash, Canon EF 50mm f/1.8 II, Canon EF 17-40 f/4.0 L, Canon EF 24-105 IS L, Canon EF 28-135 IS, Canon EF 70-200 f/4.0 L, Sigma 150-500 EX DG, Manfrotto 055XProB Tripod, P.O.T.N. Pro Strap (black)http://HerbDunn.com (external link)
BEEEsH
Apr 16, 2007 03:04 |  #12
What does it mean to have a lens calibrated?
Whats the process involved?
EOS 5D MK II
sebr
Apr 16, 2007 03:10 as a reply to  @ BEEEsH's post |  #13
It is a very versatile lens. It has a good range (although it lacks a bit on the wide side), it as a stabilizer and it is relatively cheap. What else can you ask ? :D
Sebastien
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
aliflack
Joined Aug 2004
Apr 16, 2007 06:39 as a reply to  @ sebr's post |  #14
It was my third lens (behind the kits lens and bought at the same time as the 50 F1.8) and until I added the 85mm F1.8 and the 70-300 IS it was the lens I used most of the time.
Sharp from 6.3 with lovely colour and contrast for the budget, not to mention the IS and the relatively long reach I think it's a great walkabout lens for beginners thru advanced amateurs.
Sure it hasn't got amazing build or optical quality like the L's, but then it doesn't cost anywhere near the same!
40D, 16-35L F2.8, 24-70L F2.8, 70-300mm IS, 100mm F2.8, 85mm 1.8, 50mm 1.8, Elinchrom D-Lites, Mid Octa, 580 EX
My Portfolio: Alistair Flack Photography (external link)
JohnJ80
Apr 16, 2007 07:10 |  #15
BEEEsH wrote in post #3048960 (external link)
You send it in to Canon (preferably along with your camera) and they adjust both to make sure they are completely in spec against a "gold standard" test lens. Both have adjustments that can be made.
J.
Obsessive Gear List
2,150 views & 0 likes for this thread, 16 members have posted to it.
28-135 mm Canon
1863 guests, 100 members online
