Thread started 16 Apr 2007 (Monday) 04:08
Should I borrow a lens for the wedding?
TheShootist
Apr 16, 2007 04:08 |  #1
Hi all,
I know you must here the same questions again and again, but this is specific to my equipment and my friend's, so I hope you'll bear with me.
I'm going to my cousin's wedding at the end of the month. I'm sure that she's hired a professional photographer or two (seems like it will be a fancy wedding--at least a good deal fancier than mine was :) but I'm bringing along my camera, and if I could give them a good candid shot or two, I think it would be worth it. I'm not going to try to "cover" the wedding, but my aunt's been good to me, so that I'd like to be able to send her some decent shots afterwards.
My equipment:
20D
420ex
kit lens
50mm 1.8 II
My question is:
Is it worth it for me to hit up my friend at work to borrow his 17-40 f/4L or 70-200 f/4 L lenses? He would probably be ok with loaning them to me, but it would mean that I would have to worry about things a little more during the wedding/reception since I'd have $600 on the front of my camera instead of $70. If you think I'll get 80% of the same shots with the 50mm prime, then I'll probably just stick to that.
Any comments are appreciated.
One other question: is it worth it to make a foam bounce card for the flash? The ceremony is outside early evening and I assume high ceilings for the reception.
mizuno
Apr 16, 2007 04:43 |  #2
Make sure you talk to the Pro(s) before you take any photos and make sure they're ok with you shooting and if they're fine with it make very sure you don't get in their way.
For candids, I would just take the 50 1.8 and shoot wide open, available light, high ISO if needed. Don't go flashing all over the place, you'll only get on the guests and pro's nerves.
DAN CRIPPS PHOTOGRAPHY (external link) | BLOG (external link) | PITBULL MANSION (external link)
30D x 2 | EF-S 10-22 | EF-S 17-55 2.8 IS | EF 50 1.4 | EF 70-200 2.8 IS L | 580EX x 2 |
tim
Light Bringer
Apr 16, 2007 05:47 |  #3
Use the kit lens, it's not so bad as most people think, especially if you have a lens hood. maybe check with the pro but they should be used to guests with cameras, even DSLRs and people with L lenses. I'm waiting for the day a guest shows up with a 1 series, L lenses, and still takes worse photos than me with whatever I happen to have - 20D/30D.
For wedding outside in sun try ISO100, F12, flash on ETTL. For inside try ISO800, F5.6, 1/100th. I wouldn't shoot the 50mm F1.8 wide open because its focus sucks, actually I wouldn't shoot with it at all.
Tired of typing now, just go, enjoy it, and get some nice moments, shoot auto if you have to the camera generally does an ok job at that.
Tish
Apr 16, 2007 11:53 as a reply to  @ tim's post |  #4
+ 1 to Tim's recommendations. My last wedding as a guest was shot mostly with the 100 mm macro. Anything will work for decent snapshots.
And yes, it's worth it to make a better bounce card. You'll definitely want it for the reception.
Good luck!
I've finally started a blog. Really. (external link)
davidgr
Apr 16, 2007 16:25 |  #5
tim wrote in post #3049296 (external link)
Lens hood or not, that kit lens is worth exactly what you paid for it...about $50. I have some older EF zoom lenses that take better pics than that POS kit lens.
If you're worried about borrowing your friend's lenses, rent them from someplace (rentglass.com to name just one of may sources).
David
Canon 20D & 30D, EF 28-80, EF 75-300, 17-35L, 24-70L and 70-200L f/2.8 IS, 8x1GB Sandisk Ultra II CF, Quantum T5D flash on a Custom Bracket 35-EV powered by a 80W DigitalCameraBattery. Sekonic L-358 light meter.
Older Elan IIe (you remember the film days, don't you?)
tim
Light Bringer
Apr 16, 2007 18:06 |  #6
davidgr wrote in post #3052125 (external link)
Take a look at this thread for shots all taken with the kit lens. It's not a bad lens, I don't use it but it can give decent results.
davidgr
Apr 16, 2007 20:48 |  #7
Yep, some nice looking snaps...on my monitor. Take the same shot with another lens, make some 11x14's and you'll see a difference. Maybe not so bad on a 4x6 or 5x7, but you'd still probably be able to tell which lens was used.
David
tim
Light Bringer
Apr 16, 2007 20:53 |  #8
davidgr wrote in post #3053639 (external link)
So pretty much suitable for the original posters use. We have to remember to recommend gear that's fit for purpose, and 11x14" prints aren't likely given the requirements.
blackshadow
Mr T. from the A team
Apr 16, 2007 21:37 |  #9
Great advice above but if you could borrow your friend's 70-200 I would - the extra zoom range makes for great candid shots.
Black Shadow Photography (external link)
Facebook (external link) Flickr (external link) Twitter (external link)
Gear List Myspace (external link)
TheShootist
Apr 18, 2007 02:37 as a reply to  @ blackshadow's post |  #10
Thanks everyone for the great advice. I don't think I'll be doing too many group shots so I'll probably stick with the 50mm for most things but I'll bring along the kit just in case.
For those times when I'm not using a flash, is it worth it to keep the 420 on for the AF assist (but not flashing by using the custom function)?
tim
Light Bringer
Apr 18, 2007 03:10 |  #11
TheShootist wrote in post #3061118 (external link)
Yes, especially inside. Outside flash should be on as fill.
3,134 views & 0 likes for this thread, 6 members have posted to it.
1820 guests, 119 members online
