Thread started 18 Apr 2007 (Wednesday) 01:47
Opoinions on these Ebay Softboxes $70 for TWO
Stackinchips
Apr 18, 2007 01:47 |  #1
This guys is local from me. A 45 min drive. Possibly thinking about getting these. Money is very very short for me right now. And I want softboxes more than anythign for my alienbees.
http://cgi.ebay.com …79008QQrdZ1QQcm​dZViewItem (external link)
What do you think about these? Or is it worth just getting the alien bees?
Also do you think they''d even fit?
Canon 24-70 F/2.8L
Alien Bee's
http://www.myspace.com​/jdiazphoto (external link)
moviemaker
Apr 18, 2007 06:52 |  #2
I have ones very similar to these, although mine are 90 x 90. I must admit, you get some great ohotos with the boxes.
|| 5D || Canon 70-200 USM IS L || Another 5D || 28-105 USM || Tamron 70-300 || Sigma 70-200 || 2x Converter || Extension tubes || 580EX || 550EX || Canon 15mm Fisheye || Canon CP-E4 || Lowepro AW CompuTrekker ||
Stackinchips
Apr 18, 2007 10:59 |  #3
Thanks man, I think I just might go ahead and get them. Beats spending $100+ each, especially when the money aint coming through...
Any other opinions or "NO GO's" ?????
Canon 24-70 F/2.8L
Alien Bee's
MPG ­ Photography
Joined Jul 2004
Apr 18, 2007 11:16 as a reply to  @ Stackinchips's post |  #4
I was looking at those too (local as well)....did you see that he put them on Craigslist last week for $30/ea?
Here is the listing... http://sfbay.craigslis​t.org/sby/pho/31262760​5.html (external link)
Let me know how they work out and I'll probably pick up a set. :)
Canon 6D ~ Canon 17-40 f/4 L ~ Canon 24-70 f/4 L IS ~ Canon 70-200 f/4 L IS ~ Canon 40mm f/2.8 Pancake ~ Canon 50mm f/1.8 ~ Canon 600EX-RT Speedlight
cskn0125
Apr 18, 2007 11:18 |  #5
I'm not sure if it matters, but it does not look like the front is entirely covered. Just looks like a diffuser directly in front of the strobe which then spread the like using the box.
I wasn't sure if that was a concern but I just thought I'd help you out. Great price though...I would try them out for that price.
PORTFOLIOexternal link // FACEBOOKexternal link // TWITTERexternal link // BLOGexternal link
moviemaker
Apr 18, 2007 11:27 |  #6
good point cskn.
Mine have a diffuser and than a panel that slips over the entire front. If you enlarge the photo that shows the rear, you will notice strips of Velcro, which holds the front cover on
zacker
Joined Jan 2005
Apr 18, 2007 11:33 |  #7
add says it comes with a front cover... so im thnking its got a white cover to go on the front OVER the diffuser...
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
Stackinchips
Apr 18, 2007 11:35 |  #8
Yea unfortunetly he did not show a picture (w/o the flash going off) of the front cover. Hopefully that is just the internal diffuser we are see'ing... You know what I found another auction for 2 36x36 (which would be a better size for me anyways). They are around $60 too, after shipping. I am going to go pick those ones up and order them today.
Oh and Matt.. yeah thats the craigsist ad I saw today and went to his eBay id from there.
Canon 24-70 F/2.8L
Alien Bee's
FlashZebra
This space available
Apr 18, 2007 15:31 |  #9
I have used the very inexpensive softboxes as cited above, and much more expensive expensive softboxes from Photoflex and Chimera.
I cannot tell any difference in light quality.
The more expensive units are typically more robust and accommodate standard speedrings.
The inexpensive units typically come with a one size "fits nothing really well" speedring.
I have made mechanical "bushings" to adapt the tension rods that come with the inexpensive softboxes to the more standard speedrings (these standard speedrings custom fit various flash heads and fit nicely, unlike the speedrings that come standard with the inexpensive softboxes).
Enjoy! Lon
Ray ­ Marrero
Gallery: 23 photos
Apr 18, 2007 15:53 |  #10
I have a set and after a while of setting up and putting away, the corners broke through. I guess if you set it up permanently it should last a long time. I travel with mine so I need to sew some type of re-enforcement to the corners.
The lighting is great though.
Ray
Canon 6D, 7D, 30D, Flashpoint Zoom Li-on R2 x2, Flashpoint eVOLV 200 and XPlor 600, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 24-105mm 4.0L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
Pinto
Always in our hearts and minds. R.I.P.
Joined Jan 2005
Apr 18, 2007 21:52 |  #11
Stackinchips wrote in post #3060985 (external link)
Buy it for $26.00, shipping is $36.00!?? This is where some e-bay merchants get to you. With shipping they are $62.00 each. Not so cheap.
siejoka
Apr 18, 2007 22:47 |  #12
Hey, this seems like a pretty nice entry level softboxes, let us know how it performs Stackinchips. Also, I wonder if the supplied speed ring would fit ABs?
-You can bluff, but you gotta know when to fold -
www.christiansuwarna.c​om (external link)
FlashZebra
Apr 18, 2007 22:55 |  #13
siejoka wrote in post #3066653 (external link)
Fit is a relative term.
The supplied speedring will not fit in a positive manner (like the Alien Bee or other "standard" speedring will fit). In other words it will not fit like a speedring specifically designed to fit on the Alien Bee units (or any other flash manufacturer).
In addition, to use the tension rods that come with the inexpensive softboxes with a "standard" speedring, you must modify the tension rods by adding bushings on the tension rod ends where they fit in the "standard" speedring.
I custom machined my own bushings for this adaptation and I am considering producing a home brew kit so others can do this (use these inexpensive softboxes with a "standard" speedring), I just have not got it together just yet.
These inexpensive softboxes are a good buy, they work nicely, but the supplied speedring is nothing you would want to use.
But, team the inexpensive softboxes with a "standard" speedring and then you have a good combo. But, you have to customized the inexpensive speedring tension rods to pull this off.
Enjoy! Lon
Stackinchips
Apr 19, 2007 01:17 |  #14
Pinto wrote in post #3066424 (external link)
Well it's actually a package of two... well then I guess if you add in the $30 AB speedrings thast $60+ more. Im gonna get them and see how the cheapo rings work.
Canon 24-70 F/2.8L
Alien Bee's
FlashZebra
Apr 19, 2007 01:21 |  #15
Stackinchips wrote in post #3067188 (external link)
Please post your observations and impressions on the speedrings after you get them. I am curious to know your take on the one size fits all speedrings.
Enjoy! Lon
2,789 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is Dannal01
977 guests, 181 members online
