Thread started 18 Apr 2007 (Wednesday) 03:33
need a hand with a couple of pics please
chet79
Apr 18, 2007 03:33 |  #1
Hi - I took these two photos of friends of mine at a wedding a few weeks ago, and really need a hand with processing them. I reckon I need to use levels and I also need to do something to remove the "flash spot" on ther forehead in both (blur tool? or dodge/burn maybe?). And yes, he has naturally bad skin.
First one:
IMAGE: http://img.photobucket.com/albums/v312/chetau/IMG_8826_resize.jpg
Second one:
I would either crop it portrait orientation or clone out the flash spot on the window behind for starters.
IMAGE: http://img.photobucket.com/albums/v312/chetau/IMG_8827_resize.jpg
tim
Light Bringer
Apr 18, 2007 05:40 |  #2
#1 - levels - or auto levels, then healing brush for hot spot on forehead.
#2 - crop or patch tool.
Do you want to know how, or do you want someone to do it? If you want someone to do it you're better off posting links to the high res high quality files on a web server somewhere.
ssim
Joined Apr 2003
Apr 18, 2007 10:12 |  #3
Also if you want someone to do it for you and repost the results you need to change your profile to allow image editing.
chet79
Apr 18, 2007 19:07 as a reply to  @ ssim's post |  #4
A-ha. Wasn't aware of the profile setting. OK changed now.
Ultimately, I'd like to edit the pics, but I'd also really appreciate it if people would show me what they can do :)
I'll provide a link to the full-res images later tonight.
esheato
Apr 18, 2007 20:50 as a reply to  @ chet79's post |  #5
Something like this?
I selected the red facial features and did a hue and saturation adjustment. Adjusted contrast and removed flash with the patch tool. Cleaned up bags under eyes and added a bit of USM and noise reduction.
Ed
http://www.esheato.com (external link)
ayreonaut
Apr 20, 2007 14:48 as a reply to  @ esheato's post |  #6
The backgrounds are basically useless, so why not chuck them?
Here's my crack at the first one. Try the second one yourself!
http://www.flickr.com/​photos/96996633@N00/ (external link)
davesrose
Title Fairy still hasn't visited me!
Apr 20, 2007 15:17 as a reply to  @ ayreonaut's post |  #7
This is fun...well this is my couple mins in PS. Duplicated some layers to adjust curves in skin tones. To further even out your friend's skintone, I added a couple blend layers and painted in some lighter skin tones.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
1,014 views & 0 likes for this thread, 6 members have posted to it.
2585 guests, 173 members online
