Thread started 24 Apr 2004 (Saturday) 02:26
300D auto-focus problem
frahm
Joined Dec 2003
Apr 24, 2004 02:26 |  #1
Hi Folks,
I have had my 300D for 6 months and today all of a sudden the auto-focus stopped working ( i.e. still moves the lenses but the non-focus light shows and shutter button won't work). The instruction manual is not much help, it just says if the auto-focus does not work use manual focus.
Has anybody else struck this problem? ( the manual focus is working fine but the 300D will go back to the shop on Monday.)
- Jay Frahm.
Canon 300D
Canon Ixus.
cmM
Joined Apr 2004
Apr 24, 2004 06:09 |  #2
Have you tried another lens ?
Are the contact clean ?
robertwgross
Joined Nov 2002
Apr 24, 2004 09:00 |  #3
Test it in bright light with a high-contrast subject.
---Bob Gross---
MarkK0120
Joined Mar 2004
Apr 24, 2004 11:33 |  #4
I had this happen after switching between manual and auto focus several times with my 300D/50mm 1.8. I turned the camera off, took off the lens, replaced the lens, turned camera back on -- it works fine now. Hope this helps.
Mark
frahm
Joined Dec 2003
Apr 25, 2004 02:46 |  #5
Thanks for your replies - unfortunately it is the same result with all three lenses: 18-55mm, 75-300mm and 50mm.
At least it is still under warranty but I hate the prospect of being without the 300D while it is sent away to be checked/repaired.
Thanks again for your advice.
- Jay Frahm.
Nigel ­ Wallace
Joined Feb 2004
Apr 28, 2004 11:18 |  #6
Yep, I had the same problem , in the end i got a new camera out of the company that sold it to me. I did not trust it to happen again so as it was under 6 months they replaced it for me. Thats the route i would take again[B]
Nigel Wallace
Canon 30D,
Tamron AF 70-300mm f/4.0-5.6 SP Di VC USD XLD
Canon ef 50mm 1.8, Speedlight 550ex
Sigma 10 - 20 DC
robertwgross
Joined Nov 2002
Apr 28, 2004 12:16 |  #7
What mode is the camera in? (Tv, Av, etc.)
---Bob Gross---
Ken ­ Fong
Joined Jun 2002
Apr 28, 2004 12:22 |  #8
How awful! When you change your lenses, do you always power off first? (I'm not sure if leaving the power on during lens changing is bad or neutral...maybe someone else can answer that.)
frahm
Joined Dec 2003
Apr 29, 2004 02:34 |  #9
I took the 300D back to shop on Monday morning (26 April) and got it back from Canon this morning (29 April). They said they had dismantled it to refit a dislodged mirror pivot - so after 8000 photos taken since last October it seems as good as new - Canon had also cleaned the viewfinder No charge, still under warranty.
I was using it on P setting when the AF stopped working.
I always switch off the camera when changing lenses.
Thanks for your interest,
-- Jay Frahm.
3,243 views & 0 likes for this thread, 6 members have posted to it.
2215 guests, 138 members online
