Thread started 19 Apr 2007 (Thursday) 19:27
minor scratches on LCD
MugenRD1
Apr 19, 2007 19:27 |  #1
From my recent vacation to China, I saw some minor scratches on my newly Canon LCD screen that is most likely caused by the camera case. It looks like there are some minor hairline scratches that I can live with, but there also seems to be a few marks that looks like it might have rubbed off some of the anti coating.
Any tips would be greatly apperciated
DigitalDisaster
Apr 20, 2007 17:36 |  #2
It sounds like you might want to try using a clear stick on screen protector. They can be removed and leave no residue. There might be an ever so slight degradation in viewing the screen but it beats having the screen all scratched up. I found mine at Wal-Mart in the camera section and cut it to size to fit my screen. Has several in a package.
DigitalDisaster
Canon S1 IS - Lensmate Adapter Tube - 52mm UV - Sensor died, 9/27/08
Canon S2 IS - Lensmate Adapter Tube - 52mm UV - 52mm Circular Polarizer - Matin Hand Strap
phranc
Apr 21, 2007 20:54 |  #3
Is that the same stick on stuff that is sold for the Palm Pilot ??
EORI
Apr 21, 2007 21:43 as a reply to  @ phranc's post |  #4
The LCD has a protective plastic shield that you can obtain a replacement from Canon for a nominal sum and DIY. Unless your scratches seriously diminish the visibility of the LCD, I wouldn't worry too much about it. Cameras are meant to be used, and if you use it, there will be the normal wear and tear.
As for the protective film, most of what's available out there are of poor quality; they obscure the LCD, and have poor adhesion qualities. After trying several types for my SD700IS and G7, I did find an acceptable high-quality film made by Hakuba/Kenko, but I've yet to find it available outside of Japan.
For recommendations on protective film, you should run a forum-wide search for "LCD film", as it is an oft-discussed subject over in the DSLR section.
1,723 views & 0 likes for this thread, 4 members have posted to it.
2126 guests, 104 members online
