Thread started 19 Apr 2007 (Thursday) 21:26
Confused about step up rings..
august23
Sensitive + Shopoholic = chick?
Apr 19, 2007 21:26 |  #1
Yes I asked this question quite a few times, but still haven't made the purchase. I'm buying a 72mm CPL for my 35L, but I want it to also work with my 17-40L. Getting a 72mm to 77mm step up ring seems to make sense, but won't I have to worry about heavy vignetting or some type of similar problem?
Tsmith
Formerly known as Bluedog_XT
Apr 19, 2007 22:39 |  #2
I don't use them but it's my thinking you want to get a 77mm CPL filter to work with the ring in question. That way it'd work on the 35L. If trying to use a 72mm filter on a 77mm diameter Lens would led to darkening in the corners.
sstalker
Apr 19, 2007 22:50 |  #3
Get the 77mm CPL and a 72-77 step up ring. If you get the 72mm CPL you will need a 77-72 step down ring and would have vignetting at the corners.
Rings are listed as the lens size first and the filter size second.
Steve - Toledo
20d, 50d
EF 50 1.8 MK I, EF 28-70 3.5-4.5, EF 70-210 4.0,
EF-S 17-85, EF 100 Macro 2.8
Canon 300 EZ, 380 EX, Vivitar 283, 285HV
Jon
Joined Jun 2004
Apr 20, 2007 09:35 |  #4
Right - get the bigger filter size and get a ring to step-up the smaller lens diameter to the larger filter size. Going from a large lens diameter to a small filter is taking a step down.
Jon
Cocker Spaniels
1,476 views & 0 likes for this thread, 4 members have posted to it.
904 guests, 117 members online
