Thread started 20 Apr 2007 (Friday) 07:03
CS3 able to use CS2 Plug-in?
Graphyfotoz
Apr 20, 2007 07:03 |  #1
I have asked elsewhere with lil to no input on this.
Sooooooo I'll try here! :rolleyes:
Just curious if Plug-In's and Actions I use with CS2 will work in CS3?
Haven't seen any discussion about this.
Has anyone experimented with this yet?
I have tried copy cs2/plugins/Blah to cs3/plugins/blah and didn't work thus far.
None of em work so far!
"Blah" being the entire folder name and contents.
**I'm working with a 2.8ghz PC with a Intel P4 with HT**
Fujifilm FinePix HS20EXR 30x 16mp
Canon PowerShot SD780 IS
(Friend Me on FaceBook - Jim Bolden)
In2Photos
Apr 20, 2007 07:06 |  #2
For plug-ins you will have to check with each manufacturer to see if they work I would think. Also, you may want to double check that you are placing the plug-ins into the correct folder in CS3. Don't assume it is the same as CS2. Same for actions, although I would think these should work just fine as they only call tools within the CS environment.
Current Gear and Feedback
Tsmith
Formerly known as Bluedog_XT
Apr 20, 2007 07:35 |  #3
All the ones I have CS2 work fine in the CS3 beta version. Added them individually.
RodBarker
Apr 20, 2007 08:45 |  #4
I just pointed the CS3 plugin setting at the still installed CS2 plugin folder and I have a lot of plugins in it and the ones I tried all worked , but my curser was flashing on and off so something in there was upsetting CS3 .
Rod
Graphyfotoz
Apr 20, 2007 10:33 |  #5
edit>Preferences>plug-in's(Choose)
Got it and they work!
Thanx so much Rod!!
Can't live without my Nik Color Efex Pro Filters! :)
1,171 views & 0 likes for this thread, 4 members have posted to it.
2584 guests, 172 members online
