Thread started 21 Apr 2007 (Saturday) 07:14
CS3: Camera Raw missing from Bridge (Windows)
Rawling
Apr 21, 2007 07:14 |  #1
OK, I've recently upgraded from Photoshop CS2 to CS3, and I'm having an annoying issue and am wondering if anyone here can help.
In Adobe Bridge CS2, I could right-click a CR2 file and open it in Adobe Camera Raw WITHOUT opening Photoshop first.
In Adobe Bridge CS3, I can't. The only way I can open a file in ACR is to send it to Photoshop, which will import it via ACR.
However, sometimes I just want to process all my photos in Bridge without opening them in Photoshop.
The option to open in ACR from Bridge isn't greyed-out, it's just not THERE. Ctrl-R doesn't work. There's nothing in Preferences -> General -> Behavior along the lines of "Double click opens ARC in Bridge" like there's supposed to be (apparently). Yet the plug-in is installed in Photoshop fine.
Anyone got any tips? I've tried googling, but no-one seems to have this exact problem.
In the bag: Canon EOS 350D | 18-55mm (kit) | 70-200mm f/4 L | 17-40mm f/4 L | 100mm f/2.8 USM macro | Speedlite 580EXII
In the pipeline: No idea. Suggestions?
tim
Light Bringer
Apr 21, 2007 08:29 |  #2
Reinstall. CS3 works the same as CS2 did for you, but I find Adobe very crap in general for usability.
Rawling
Apr 21, 2007 12:37 |  #3
I've already reinstalled once, no go. Might just have to get used to this ¬.¬
tim
Light Bringer
May 03, 2007 23:00 |  #4
I'm having the same problem, after upgrading from the beta version to the full version. No solution but a couple of interesting threads, neither helped me though.
http://www.adobeforums​.com/cgi-bin/webx/.3bc3b444 (external link)
http://www.adobeforums​.com/cgi-bin/webx/.3bc3b5b8 (external link)
If anyone finds a solution would be happy to hear it.
René ­ Damkot
May 04, 2007 05:07 |  #5
Here (external link) is a thread (on a different forum) about it...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tim
Light Bringer
May 04, 2007 05:48 |  #6
Thanks Rene. I can't be bothered registering for yet another forum. CS3 installed fine for me, after a regular uninstall of cs3 beta, only problem is can't open ACR from bridge.
djdeeb
Jul 09, 2007 13:37 |  #7
I have the same problem now.
It was working fine from when I originally installed it a couple weeks ago until yesterday where now the ACR options got removed. I have no idea why ACR would all of a sudden get removed from Bridge. I tried everything from uninstalling and reinstalling to reloading WindowsXP from scratch and installing CS3. No luck.
chris.bailey
Joined Jul 2003
Jul 11, 2007 02:16 |  #8
I had huge problems with Bridge when I first installed CS3 after the Beta even though I followed all the uninstall instructions to the letter. The CS3 update, however, solved all of them so if you have not done so that is worth trying.
Longwatcher
obsolete as of this post
Joined Sep 2002
Jul 11, 2007 03:51 |  #9
I have a related, but slightly different problem, I can't double click in bridge and send to photoshop - even a jpeg - I have to open ACR first -which works fine from bridge for me.
Problem cropped up after I downloaded and ran the ACR update for CS3, before that mine was running fine as it was supposed to. I am not touching the software until Adobe comes out with the next update as all it means is I have to right click and open in ACR before sending to PS, but that is okay as I like what it does for jpegs as well.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
jkoc
Jul 11, 2007 11:36 |  #10
had the same problem .. looked at all sorts of forums and such on this..
gave up and just started using lightroom trial instead...
Zenzin
Apr 03, 2008 22:31 |  #11
-- Fix! --
Hey guys, I had this same annoying issue where I couldn't open RAW files in Bridge. I finally found a fix. (yes, I realize it's a late post hah)
Just Open Bridge, go to Help at the top and Update..
Once the update finishes, RAW should work once more.
Current Body: EOS 40D
Current Lenses: EF 28-135mm IS USM
tim
Light Bringer
Apr 03, 2008 23:12 |  #12
That didn't work for me. Glad it helped you tho.
partsman
Apr 04, 2008 12:24 as a reply to  @ tim's post |  #13
i assime you already tried this but i thought i'd post just in case.
The neat thing about Adobe Camera Raw is that both Photoshop and Bridge utilize it independently of each other.
To process Camera Raw files in Adobe Bridge before getting to Photoshop:
  1. Go Edit > Preferences > General tab.
  2. Then tick/enable ‘Double-Click Edits Camera Settings in Bridge’. This setting basically fires the Camera Raw module within Adobe Bridge for further processing.
If it is not ticked, then Bridge will minimize and Photoshop will maximize and handle the Camera Raw processing.
Mark
50D l 350D l 70-200L f/2.8 IS l EFS 17-85 f4.0-5.6 l 50 f/1.4 l 430EX
Zenzin
Apr 04, 2008 14:16 |  #14
partsman wrote in post #5259465 (external link)
HTTP response: NOT FOUND | MIME changed to 'text/html' | Content warning: script
I had this checked already, but either way, you should still be able to open it within bridge by right clicking on the RAW file and choosing the Camera Raw option. The issue was that the option for Camera Raw was not present. The update fixed my issue with that right after it had finished.
tim
Light Bringer
Apr 04, 2008 17:47 as a reply to  @ Zenzin's post |  #15
Here's where the problems start... see attachment. I just use ACR in photoshop, it's a little slower for my workflow but it works fine.
15,950 views & 0 likes for this thread, 10 members have posted to it.
1701 guests, 166 members online
