Thread started 21 Apr 2007 (Saturday) 07:58
CS3 Bridge only pictures
mantra
Apr 21, 2007 07:58 |  #1
Hi
i did upgrade to cs2 to cs3
i like the new version
but i have a question
in bridge i see photos , movies , programs and so on
is there an option to see only photos?
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
Rawling
Apr 21, 2007 08:03 |  #2
Um... I might have an answer.
IN the bottom left you should see a "filter" pane. At the top of that should be a list of files types in the current folder, with a count of how many of each is present.
If you click to "tick" a file type, all the others will be filtered out. Simply "tick" each photo file type you want to see.
Good luck.
In the bag: Canon EOS 350D | 18-55mm (kit) | 70-200mm f/4 L | 17-40mm f/4 L | 100mm f/2.8 USM macro | Speedlite 580EXII
In the pipeline: No idea. Suggestions?
mantra
Apr 21, 2007 08:17 |  #3
Rawling wrote in post #3079119 (external link)
Good luck.
thanks !
right it works
but can i save the filter?
so every time i run bridge i can see only photos ,jpg and raw?
Rawling
Apr 21, 2007 08:18 |  #4
Heh, no idea. I'm new to this version myself :p
ssim
Joined Apr 2003
Apr 21, 2007 09:51 |  #5
mantra wrote in post #3079167 (external link)
thanks !
You can go under Window in Bridge and select workspace and save it to a name that you will remember. It remembers everything about how you are using it. For some reason if it defaults back to the old workspace you can reload this and be back where you want to be.
mantra
Apr 21, 2007 11:51 |  #6
ssim wrote in post #3079453 (external link)
thanks for the info
i tried but i doesn't store the filter files
mantra
Apr 23, 2007 01:48 as a reply to  @ mantra's post |  #7
Does somebody know how SAVE filters in bridge CS3
960 views & 0 likes for this thread, 3 members have posted to it.
2766 guests, 179 members online
