Thread started 26 Apr 2004 (Monday) 10:17
FlashTrax Feedback
Pixi
Joined Apr 2004
Apr 26, 2004 10:17 |  #1
Does anyone here own a FlashTrax?
http://www.smartdisk.c​om …lMultimedia/Fla​shTrax.asp (external link)
I'm interested in ordering one. Would love to have feedback on it.
Linda
Linda
chris.bailey
Joined Jul 2003
Apr 26, 2004 11:29 |  #2
Love it -
Plus points -
* Good screen
* Resonably fast
* Updateable OS
* Holds lots of piccies
* Will display RAW from the 10D (not sure about anything else)
* Reasonable fast.
* Does not need an external card reader
Minus points -
* Battery life, buy a spare.
* Feels a little flimsy
* Menu system takes a bit of getting used to.
* Expensive in the UK
*I'm sometimes not confident that I am not copying things into a black hole (I have though never lost anything)
Would I buy it again. Yep. On a recent holiday I brought back some 1500 pictures and there was still loads of room on it.
Pixi
Joined Apr 2004
Apr 26, 2004 11:40 |  #3
Thanks Chris! ... very much! :)
Linda
psk4363
Joined Jun 2003
Apr 26, 2004 12:47 |  #4
HI Linda,
I'm with Chris re his pros and cons. I've had the 40Gb version for a month now and but haven't really pushed it to the limits yet but so far it's performed well above my expectations. Transferring data via the USB 2 port is extremely fast, the screen is excellent and I love the way you can zoom into the image and navigate around it.
Highly recommended.
Cheers,
Barry
A little G9 :D
Pixi
Joined Apr 2004
Apr 26, 2004 12:58 |  #5
Thanks Barry.
I have the G4 DP Mac. Do I need to upgrade a card or something to take advantage of the USB2 speed increase?
Linda
jimtfoto
Joined Apr 2004
Apr 26, 2004 13:57 |  #6
I have had the 30GB unit for a few months and it's saved me the hassle of hauling about my laptop when I know a shoot is going to fill more than a couple of cards (carry two 512mb cards). I also sometimes get concerned about the "black hole" syndrome, but always check the files on the drive before dusting them from the cards.
As has been mentioned, one of the major downsides is battery life. However, I've yet to run into a problem since I charge the night before a shoot. Second battery might be useful.
Bit more of background ... before I finally tracked down the Flashtrax in Toronto (the big camera chains don't seem to be interested in it, for some strange reason) I had purchased Delkin's picture pad. This came with a 1-inch viewscreen and 20 GB of storage. Price was several hundred more than the Flashtrax. Big disappointment ... impossible to see preview pix with these older eyes, plus it refused to display some pix it said had too large a file size. Kept that for all of two days before returning for a refund, which was like pulling teeth at the camera store.
Anyway, despite its downside, my vote goes to Flashtrax ...
jim
www.pix2go.ca (external link)
Sometimes I do get to places just when God is ready to have somebody click the shutter.
- Ansel Adams
Jesper
Joined Oct 2003
Apr 26, 2004 14:35 |  #7
Yes, I have a 40 GB FlashTrax. I ordered it on the web from the UK, and the first unit I received stopped working after 2 hours of use or so. I phoned SmartDisk support, a few days later I got a return number and sent the unit back. About two weeks later I had a working unit.
The LCD screen is nice - it's larger than the camera's screen, but the resolution isn't very high (it has quite big pixels). Also, the FlashTrax seems to be a lot more expensive than some other portable hard drives. I would have gotten something cheaper if I were buying one now.
It is also capable of displaying Canon RAW files (or rather, the embedded JPEG images inside CRW files).
Canon EOS 5D Mark III
gordeaux
Joined Feb 2003
Apr 26, 2004 15:08 |  #8
I've been using the 80GB version for about 6 months. Mostly with 2x 1GB cards and a 10D. It has always copied the contents of the card to the FlashTrax faster than I can fill the second card. So that's meant I've never run out of film. Mentally I found having only two CF cards easy to work with. The card is either in the camera or it's ready to go into the camera, nothing to get confused about.
Out of about 10,000 pictures I've transferred, 3-4 batches failed for no apparent reason. Since then I've changed the shutdown timer to 30 minutes to make sure I see the confirmation message before I reformat the CF card. Hard drive, screen, everything else powers down in 1 minute. I just want to preserve the confirmation message until I get around to looking at it (usually within 10-15 minutes). Haven't had any problems since then.
Longest shoot I've had with it was about 1,500 pictures over about 14 hours and the battery on the FlashTrax gave out just as the shoot ended. Lately, however, I've had the FlashTrax battery give out after about 800 pictures though, so I'm not sure what caused the variation. I'm getting a 2nd battery next time I order some supplies.
Canon 30D * Sigma 14mm / Canon 28-138 IS / Canon 100-400 L IS / PhotoShop CS2 / FlashTrax
Pixi
Joined Apr 2004
Apr 26, 2004 17:20 |  #9
Thanks to all who've continued to respond. I'm following along.
Gordeaux: You mentioned that you only have two cards that you like to work with. Would you care to elaborate on that?
Linda
gordeaux
Joined Feb 2003
Apr 26, 2004 17:25 |  #10
I'm using two 1GB Lexar 40X cards. That's about 150 images capacity on each card. Somewhere over 100 images, when there's a break in what I'm shooting, I pop the card out of the 10D and into the FlashTrax, start copying, put the other card into the camera, format it, confirm that the FlashTrax is indeed copying, then am ready to resume shooting.
Pixi
Joined Apr 2004
Apr 27, 2004 08:37 |  #11
Thanks very much!
I'm putting together my order today. I need a zoom, 3 1GB cards, a backup battery, 550EX flash, and still debating on the Flashtrax. :)
Linda
Canuck
Joined May 2003
Apr 27, 2004 09:01 |  #12
Am I too late to add into this one? I have a 40GB Flashtrax Drive! I am trying to sell it, only for one reason...I'm using a ton of space and trying to upgrade to 80GB one. Failing that it is great. I have more info for later.
robertwgross
Joined Nov 2002
Apr 27, 2004 11:01 |  #13
Pixi wrote:
Thanks very much!
I'm putting together my order today. I need a zoom, 3 1GB cards, a backup battery, 500EX flash, and still debating on the Flashtrax. :)
What is a 500EX flash?
---Bob Gross---
chris ­ maddock
Joined Mar 2002
Apr 27, 2004 12:34 |  #14
robertwgross wrote:
Pixi wrote:
Thanks very much!
---Bob Gross---
It's a 550EX with low batteries ;-0
Chris
Chris Maddock
Southampton, UK
http://www.dslr.co.uk (external link)
Pixi
Joined Apr 2004
Apr 27, 2004 13:13 |  #15
Canuck: Glad to know you like it. Maybe I should aim for the big one too.
Sorry guys... I meant to say 550 EX... but you knew that didn't you. :wink:
Linda
6,042 views & 0 likes for this thread, 15 members have posted to it.
FlashTrax Feedback
1747 guests, 132 members online
