I want to get rid of the heavy contrast of shadow/light in this photo. I'd like to bring both extremes a little closer together. How would I go about doing this?
retro Senior Member 500 posts Joined Jun 2004 Location: Alberta, Canada More info | Apr 22, 2007 01:11 | #1 I want to get rid of the heavy contrast of shadow/light in this photo. I'd like to bring both extremes a little closer together. How would I go about doing this? Canon 5D, 20D,50mm1.4, Canon 24-70 2.8L, Canon 15mm fisheye, Canon 16-35 2.8L
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Apr 22, 2007 01:19 | #2 Permanent banPS shadow/highlight Photographic Resources
Kristy Cream of the Crop 10,583 posts Gallery: 31 photos Best ofs: 1 Likes: 77 Joined Sep 2005 Location: A dream world where nothing is what it seems. More info | Apr 22, 2007 01:20 | #3 That's going to be tough with this image.. If you shot in raw, you can process 2 images... bump up the exposure on one of them to lighten the dark side of her face, Life is not measured by the number of breaths we take,but by the moments that take our breath away.
Thanks a lot. I am sleepy now, but I will try these in the morning. Cheers. Canon 5D, 20D,50mm1.4, Canon 24-70 2.8L, Canon 15mm fisheye, Canon 16-35 2.8L
ayotnoms Perfect Anti-Cloning Argument 2,988 posts Joined Jan 2005 Location: San Francisco Bay Area More info | Apr 22, 2007 02:20 | #5 It may take a little experimentation on your part but one suggestion is to copy your image to a second layer in Photoshop and change blend mode to Screen. Copy the Red Channel from the original image (because it has greater contrast than the other color channels). Using Levels, alter the Red channel with the intent of creating something that will later be used as a layer mask. I used the black dropper to more clearly delineate the areas where the original image would poke through and the white areas where the Screened layer would show through. Additional steps: invert the modified Red channel (which should now be either all black, white, and a little grey for areas where there's a need for a smooth transition between shadows and highlights). Apply a small amount of Gaussian Blur. Add a Layer mask to the 2nd, Screen-mode layer. Load the Red channel as a selection so you can leave the light areas as is, and allow the Screen mode to brighten the overly dark areas of the image. Steve
jr_senator Goldmember 4,861 posts Joined Sep 2006 More info | Apr 22, 2007 07:15 | #6 |
rammy Goldmember 3,189 posts Likes: 4 Joined Oct 2004 Location: London, England More info | Apr 22, 2007 07:53 | #7 Some fill in flash would have certainly helped at the time of taking this shot. Gear | Surrey Wedding Photographer
| Latest registered member was a spammer, and banned as such! 2767 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
