The attached picture was taken on a cloudy day. I used PS CS to brighten it somewhat but question whether or not I made the right adjustments.
Please critique.
http://www.pbase.com/image/28359366.jpg![]()
Bunzo Mostly Lurking 11 posts Joined Apr 2004 More info | Apr 26, 2004 20:32 | #1 The attached picture was taken on a cloudy day. I used PS CS to brighten it somewhat but question whether or not I made the right adjustments.
kb244 Senior Member 766 posts Joined Jun 2003 Location: Grand Rapids, Michigan More info | Apr 26, 2004 22:48 | #2 Try the "Warming" Filter, under Adjustments... Photo filter. -Karl Blessing
Daytripper Member 82 posts Joined Aug 2003 Location: Perth, Australia More info | Apr 26, 2004 23:08 | #3 Your histogram looks as though some of the detail in the highlights may have been blown during brightening - perhaps try some local contrast enhancement with unsharp mask on the original to increase the contrast in the shadow areas, or use the 'shadow / highlights' adjustment to lighten the darker areas. I guess it depends how much detail is present in the original.
Meerkat17 Goldmember 1,868 posts Joined Jan 2004 Location: Durham UK More info | Apr 27, 2004 03:01 | #4 Why not post your image on Post-pocessing and Printing and make the original available for other members have a go so they can give you better direction, you will see many different results and find out how they have been achieved. David
iwatkins Goldmember 1,510 posts Likes: 1 Joined Sep 2003 Location: Gloucestershire, UK More info | Apr 27, 2004 03:42 | #5 My attempt:
I increased the saturation slightly then used Curves to bring out more detail in the various components at the same time as reducing some of the haze/salt spray. Increased the contrast as well. Cheers Ian
| Latest registered member is IoDaLi Photography 1687 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
