I have CS2.... I have an image that I would like to fill a shadow. When I use the "Pattern Maker" filter it just tiles the new pattern across the whole image. The only way I could see to use it this would be to create a second layer that has the patten, then lower the opacity of the shadow on the layer with the image so the pattern shows through.
It seems that you can use the paint bucket with the preset patterns. Is there a way to add my own pattern from a selection then use the bucket tool on a selection?
