Hi
Anyone know how they take those product photos that seems to float in a white background like this?
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Thanks and any help would be appreciated.
tradertt Hatchling 7 posts Joined Apr 2004 More info | Apr 27, 2004 08:27 | #1 Hi
Ikinaa Goldmember 1,517 posts Likes: 1 Joined Jul 2003 Location: Luxembourg More info | Apr 27, 2004 08:50 | #2 If I had to shoot something like that, I probably would use a light tent like this ...
Apr 27, 2004 08:55 | #3 Thanks
Fiberoptik Junior Member 21 posts Joined Mar 2004 More info | Apr 27, 2004 18:40 | #4 Its a photoshop technique... A simple cut and paste. Shoot your subject using a light or white background, assuming that the edges of your subject are not white, and using the magnet tool carefully cut out your subject and paste it onto a pure white background. There are many different ways of doing this. For complex subjects try using a white mask and gently paint away the parts of themask covering your subject. It can also be done using a softbox or slave flash system. Good luck
xounds Hatchling 8 posts Joined Apr 2004 More info | Apr 28, 2004 09:08 | #5 i think i could help you with this.. im a graphic designer..
tekgik Member 37 posts Joined Nov 2003 More info | Apr 28, 2004 10:22 | #6 you can use a white bended board as a backdrop to have a straight background effect. Though it still requires photoshop editing. Have a look here http://www.shortcourses.com/studio/tabletop/studio.htm
Ikinaa Goldmember 1,517 posts Likes: 1 Joined Jul 2003 Location: Luxembourg More info | Apr 29, 2004 00:43 | #7 xounds wrote: i think i could help you with this.. im a graphic designer.. its just a matter of shooting your subject in a plain background and later filling the background colour in with a colour of your choice, in this case white. this is the easiest method if youre talking about using graphical software What about the white reflection in the mirror, you have to replace that also...
xounds Hatchling 8 posts Joined Apr 2004 More info | Apr 29, 2004 07:50 | #8 Ikinaa wrote: xounds wrote: i think i could help you with this.. im a graphic designer.. its just a matter of shooting your subject in a plain background and later filling the background colour in with a colour of your choice, in this case white. this is the easiest method if youre talking about using graphical software What about the white reflection in the mirror, you have to replace that also... tts real easy too, you just fill in the area whereby the mirror reflects the white part.. its the same method as filling in the background..
Ikinaa Goldmember 1,517 posts Likes: 1 Joined Jul 2003 Location: Luxembourg More info | Apr 29, 2004 07:53 | #9 xounds wrote: Ikinaa wrote: xounds wrote: i think i could help you with this.. im a graphic designer.. its just a matter of shooting your subject in a plain background and later filling the background colour in with a colour of your choice, in this case white. this is the easiest method if youre talking about using graphical software What about the white reflection in the mirror, you have to replace that also... tts real easy too, you just fill in the area whereby the mirror reflects the white part.. its the same method as filling in the background.. I not only mean the mirror-reflected part but also the reflection on the black frame of the mirror...
MikeSaxon Hatchling 4 posts Joined Aug 2003 More info | May 02, 2004 08:36 | #10 Sure you can mask the compact, and replace the background with white, and then adjust the reflections within the mask.
| Latest registered member is Thunderstream 1253 guests, 123 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
