Thanks Jesper for the explanation.
So if I have two similar photos with similar curves with the difference being that one clips at the top and the other doesn't, is it correct to assume that the one with the clipped histogram has 'better' saturation? Or does saturation have nothing to do with this and I should just ignore clipping from this point forward?
I tried to take 4 similar shots of a given subject using both a 2.8 lens and a 3.5 lens, both at 4.5 aperture at 70mm, with and without a hood.
For the 3.5 lens, the histogram clipped only in the hoodless shot. For the 2.8 lens, it clipped in both. Granted, this was not a great test since I didn't use a tripod.
