Thread started 28 Apr 2004 (Wednesday) 00:09
More RAW pics with the DRebel russian firmware
yb98
Joined Feb 2003
Apr 28, 2004 00:09 |  #1
I have read that with the russian firmware hack for the DRebel, it is possible to take more raw pics than with the canon firmware. I'm just wondering how is this possible ? Are they some information that the russian firmware does not record ???
Yacine.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
kb244
Joined Jun 2003
Apr 28, 2004 00:52 |  #2
There is a feature in the firmware hack that allows you to change the type of JPEG saved and embeded in the raw file. By Default canon has set it to save a RAW File, but with also a Large Jpeg embeded in it, making the files roughly 6MB or so in side, the firmware allows you to change the size of the jpeg saved, most people never even use the embeded jpeg, so when you set to Raw+Small , you get a bit of extra room to save the files. The files them become on adverage 4.5MB each or so.
-Karl Blessing
PHP/MySQL Webdeveloper & Photographer.
My Website (external link)
yb98
Joined Feb 2003
Apr 28, 2004 01:45 |  #3
oh I see, Thanks.
Best DPP Threads
robertwgross
Joined Nov 2002
Apr 28, 2004 02:34 |  #4
I don't think you are trying to claim that Raw+Small will yield a 4.5MB file, are you?
Raw+anything will be at least 6MB.
Raw alone gives me at least 6MB. Sometimes 6-9MB.
Please clarify.
---Bob Gross---
kb244
Joined Jun 2003
Apr 28, 2004 03:15 |  #5
Actually , it gives me anywhere from 4.5MB to 7.5MB at the most for all my .CRW files, the sizes were somewhat larger when set with +Large JPG. My average CRW file is about 5MB
-Karl Blessing
robertwgross
Joined Nov 2002
Apr 28, 2004 12:03 |  #6
Average CRW file is about 5MB?
Very interesting!
Somebody explain how that works, because on my D60, the CRW file (Raw only, no JPEG) is 6-9MB. Most of these cameras have the same sensor size (6 Megapixels).
Is this for an ordinary (random) subject, or is this for some plain background, or test pattern? Does the 5MB figure vary with ISO?
In general, on mine, the higher the ISO, the more the color noise, so the less-compressible the CRW file is, so the closer to 9MB it is.
---Bob Gross---
nikee
Joined Jun 2003
Apr 28, 2004 12:54 |  #7
each picture has a certain amount of information in it (entropy). an uncompressed raw file does include this information plus redundant parts.
the goal of lossless compression is now to extract the entropy, so the total size decreases.
now, with high ISO, the noise adds more information to the picture. even if this is false information (it was not in front of the lens, but the sensor that created it - random noise). because random signals have the highest possible entropy rate, these raw files do not compress well - as there is simply more information contained in them.
OTOH, if you take a picture witht the cap on the lens (or even a lot of black areas, or white - whatever) - you will get a relatively small raw file (the same with JPEG), because there is almost no information in this picture.
hope this makes sense.
regards
nicola
Cadwell
Joined Jan 2004
Apr 28, 2004 13:00 |  #8
I've just checked the only set of RAW files I have on my hard disc (I can't be bothered to go and dig out any DVDs to check them). The largest RAW file is 5.8MB and the smallest 4.9MB. I would say (without doing the arithmetic but just taking a visual feel for the file size distribution) that the "average" size was around 5.2MB.
The shots were of racing cars taken at Silverstone circuit using a 10D. ISO was 400 for all shots. The camera was set to RAW (small JPEG).
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
robertwgross
Joined Nov 2002
Apr 28, 2004 14:14 |  #9
So far, you have been discussing the size of RAW+JPEG within the DRebel, and you are mentioning sizes around 5MB.
On my D60 (similar sensor), the size of RAW alone is never less than about 6MB, unless I shoot something highly compressible, like the inside of a lens cap.
Interesting.
I would have thought that the RAW non-lossy compression would be very similar between the DRebel and the D60. Now, it seems that they are not.
Hmmm.
---Bob Gross---
theoldmoose
Joined Nov 2003
Apr 28, 2004 15:11 |  #10
Aside from the fascinating RAW size versus entropy discussion, I'd like to point out that the 300D default is RAW+Medium JPEG, not large, as was stated previously.
I'm interested in the hack mainly because I'd like to actually get full-size JPEGs embedded in my RAW. If I nail a few photos with proper exposure and color balance, I may consider it redundant to develop the RAW at all.
This, I'm sure would please those that claim that they always shoot in JPEG, because they get it right (most) every time, thus not invoking a RAW post-processing penalty if not needed (but keep that 'ace-in-the-hole' for those times that their infallable mental metering system breaks down :))
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 28, 2004 21:45 |  #11
Bob just checked a bunch of 10D RAWs.. I have the smallest joeg embedded.. and the files are Averadging 5.5 MB
Maybe with the 10D Canon imcreased the lossless compression?
CDS' HOT LINKS
robertwgross
Joined Nov 2002
Apr 29, 2004 00:16 |  #12
Who did?
Mere speculation.
---Bob Gross---
LiquidDye
Joined Jul 2003
Apr 29, 2004 02:01 |  #13
Capture one raw converter
I'm by no means an expert but it would seem that there is in deed a difference between the way each of these particulaly the 300d and 10d cameras write the raw files to the cards. Why? Well if Capture one software are able to say and imbed into their software a different generic profile for each and in fact every camera then surely the reason is each camera writes to the cards slightly differently? Well it might be the reason.
robertwgross
Joined Nov 2002
Apr 29, 2004 09:46 |  #14
Unclear.
Capture One doesn't have anything at all to do with the size of the Raw file that a camera writes.
---Bob Gross---
karusel
Joined Nov 2003
Apr 29, 2004 10:51 |  #15
The only few files that I could find (I've got a 10D) and go below 5,000.000 bytes are either really dark, or really bright or somwhere inbetween but with no detail, like pure sky or fog.
The smallest crw shot has 4,321.140 bytes, interestingly the largest file that I have is shot in ISO 100 and has 8,514.954 bytes. The estimated average is a bit above 6,000.000 bytes.
Please note that 6,000.000 bytes does not equal 6 megabytes. Perhaps some people have made mistakes this way, so there are bigger discrepancies...
I think it all depends on what you shoot and how you shoot it, only a head to head comparison could prove if there actually are differences between models.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
3,185 views & 0 likes for this thread, 11 members have posted to it.
2217 guests, 138 members online
