Thread started 25 Apr 2007 (Wednesday) 23:29
Great Blue Heron - NeatImage Mistake
canonloader
Gallery: 6 photos
Apr 25, 2007 23:29 |  #1
NeatImage has it's limits. It doesn't do a good job on large crops. I was trying to clean up #1 a bit, then decided to use NeatImage on it to see what would happen this time, #2. These are the default settings.:D
#1.
#2.
Mitch- ____...^.^...____
Maureen ­ Souza
Apr 25, 2007 23:33 |  #2
Heh, heh. I have done that to faces before:oops: :oops:
5DMK4
7DMK2
AirBrontosaurus
Apr 25, 2007 23:36 |  #3
No, NeatImage just has a built-in artistic feature. It knows when you want a shot to look artistic, and automatically does it for you. It looks like it's working fine to me... ;)
JK. NeatImage isn't bad at larger crops, you just need to know how it works. It has a minimum size in order to create a noise profile. If them minimum size is too large (ie, includes grass/waves/etc), then it sees that as "noise," and tries to clean it up. You can download noise-profiles for your camera model and ISO setting, and then it doesn't have to generate it's own profile, so you can use it on larger crops. Or, just use photoshop's noise removal. It works well in situations like these.
Chris | My Flickr (external link) | AirBrontosaurus.com (external link) | Peleng 8mm Fisheye writeup (external link)
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
cosworth
I'm comfortable with my masculinity
Apr 25, 2007 23:37 |  #4
You need to download the profiles for your camera. :)
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
canonloader
Gallery: 6 photos
Apr 25, 2007 23:55 |  #5
I thought it looked neat, sort of Japanese watercolor. :D
Where do I get the profiles?
OK, found them.
cosworth
Apr 26, 2007 00:01 |  #6
http://www.neatimage.c​om/profiles.html (external link)
canonloader
Gallery: 6 photos
Apr 26, 2007 00:25 |  #7
Thanks Jason, I got them, but not sure how to use them. I can find them in the Profile dropdown, but then what, just Apply?
cosworth
Apr 26, 2007 00:32 |  #8
Yep, load them and run the defaults. Should be enough for ya.
canonloader
Gallery: 6 photos
Apr 26, 2007 00:38 |  #9
Got it, thanks. I can see I need to practice with this program some more.
scrumpy
Joined Jun 2004
Apr 26, 2007 03:50 |  #10
Run the sharpen tool over just the bird. It will look great. Looks quite ok now.
David: Canon EOS 400D - Canon EF70-300mm f/4-55.6 IS USM -Sigma 17-70 F2.8-4.5 DC Macro - Sigma 50-500 'Bigma' - Speedlite 580EX 11 - Better Beamer
Have patience. All things are difficult before they become easy ;)
village ­ idiot
Apr 26, 2007 04:27 |  #11
I've found that if you set your own noise profiles on neatimage by moving the little square to a spot devoid of clutter you can get good results with NeatImage despite it's limitations. Great program I highly recommend to anyone who hasn't downloaded the demo. Sometimes it just won't work on certain pictures, but usually it's a great help.
"Slower minds keep right..."
hTr
Apr 26, 2007 06:16 |  #12
Generally tells you that it can't find a clear area to sample when it does that for me.
gary
canonloader
Gallery: 6 photos
Apr 26, 2007 09:03 |  #13
The auto profile used a square over the water ripples, but without any warning. Probably thought the ripples were the worlds worst case of noise. :)
bromm
Apr 26, 2007 10:25 as a reply to  @ canonloader's post |  #14
And dont forget the "FADE" button Mitch. It does help in some situations with Neat image.:D
Trevor Wadman
Canon 40D/350D Canon 400L F/5.6, Canon 70-200L F/4 non IS. Tamron 100-300,Canon 18-55 Kit Lens. Canon 1.4 II Extender, Canon 430EX speedlight.
http://s41.photobucket​.com/albums/e286/bromm​/ (external link)
canonloader
Gallery: 6 photos
Apr 26, 2007 11:18 |  #15
I did use the Fade once, just to check that it worked with the plugin. I think what I need to do is to make a selection on the bird itself, run NI so it doesn't over do it, then run it again on the background selection.
What I really need to do is to read the instructions. Again. I went through them once or twice, but it's all greek to me and just moving sliders randomly can mess you up fast. ;)
1,925 views & 0 likes for this thread, 15 members have posted to it.
2839 guests, 182 members online
