Thread started 26 Apr 2007 (Thursday) 06:57
Need free flash/gif slideshow 250x200px
tim
Light Bringer
Apr 26, 2007 06:57 |  #1
Anyone know how? I'm a software developer so very PC literate but haven't done anything in flash and never made an animated gif. This is for advertising on a wedding website.
Palladium
Apr 26, 2007 07:03 |  #2
If you have or use a version of Paint Shop Pro there is a standalone application called amination shop.
Anyway the animated gif's in PSP's is really easy.
Palladium
Apr 26, 2007 07:06 as a reply to  @ Palladium's post |  #3
another thought - if you have a video clip you can usually use the export feature of your non-linera editor to export the clip as a gif.
tim
Light Bringer
Apr 26, 2007 07:06 |  #4
Don't have PSP, just photoshop CS2/CS3. Read an article today that said CS2 Imageready was ok for that but CS3 sucked. Should probably try ImageReady.
tim
Light Bringer
Apr 26, 2007 07:10 |  #5
Don't have video tools either.
wlescall
Apr 26, 2007 09:05 |  #6
The animation palette in PS CS3 may be your answer. In the latest episode of PhotoshopTV, they create an LED count down using it.
Bill
EOS 5Dmkiii, Canon EF 50mm f/1.8 mkii, 580 EX II , Canon EF 24-105 mm f/4L, Canon EF 100-400mm f/4.5-5.6L IS
2 desktops & 2 laptops (PC & Mac each)
Chronon Photography (external link)
Hellashot
Joined Sep 2004
Apr 26, 2007 11:05 |  #7
tim wrote in post #3106879 (external link)
If you're a software developer, doing this for pay I presume, why are you looking for free software? Most "freeware" is free only for personal home use and not for commercial purposes. Have you considered paying for the right to use a flash program?
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
TeeJay
Joined Jun 2005
Apr 26, 2007 15:09 |  #8
Hellashot wrote in post #3108021 (external link)
Where does Tim say he wants something for "free"?
[Edit: Duh!! - sorry, just re-read the title!]
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
Mark_48
Apr 26, 2007 16:02 as a reply to  @ TeeJay's post |  #9
Does this help for the GIF's? I haven't tried it, so I don't know how it works or how well. It's got alot of downloads so judging by that it can't be too bad.
Freebie:) :) :) :)
http://www.download.co​m …4-909432.html?tag=lst-0-2 (external link)
Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
coreypolis
Apr 26, 2007 16:07 |  #10
Image Ready will do it. you can have it as a gif, or even export it as a swf. I had one on my home page of 10 rotating images and it worked just fine.
just put all images in IR, each as a new layer, go to the animation pallete, and make 1 image for each layer, as you select each image left to right, make the top most layer hidden and keep going down the list, then once you're done, change the animation time to whatever you want.
2 minute job
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
tim
Light Bringer
Apr 26, 2007 16:59 |  #11
wlescall wrote in post #3107378 (external link)
Excellent, thanks :)
This is a trivial thing to do, it's for advertising on a website, not for customer work. Making a gif is so easy there should be free software to do it.
coreypolis wrote in post #3109617 (external link)
2 minute job
Great, just what I wanted, thanks! I've never even run ImageReady but I will tonight :)
tim
Light Bringer
Apr 26, 2007 17:01 |  #12
Just found another link too that explains how to do it - posting so anyone who does a search can find it too :)
https://photography-on-the.net/forum/showthre​ad.php?t=145939
tzalman
Fatal attraction.
Apr 27, 2007 09:14 |  #13
Simple to use little free application, UnFREEz.
http://www.whitsoftdev​.com/unfreez/ (external link)
I use it all the time to make animated birthday card gifs.
Elie / אלי
tim
Light Bringer
Apr 30, 2007 02:21 |  #14
Thanks everyone, I got the animated gif to work and the same as a shockwave thingy :) Now i'd like to have smoother transitions between the frames, rather than an instant cut maybe a 0.2sec fade. Any ideas?
TeeJay
Joined Jun 2005
Apr 30, 2007 03:35 |  #15
Tim, the best thing I have come across (although not completely "free") is almost any version of Paint Shop Pro (I still use version 5 for things like this, which you should be able to pick up for next-to-nothing)
With that app comes "Animation Shop" and that produces excellent transitions - wide variety, and you choose the timing as well. Just drag - drop the .jpg's onto the time frame.
TJ
2,364 views & 0 likes for this thread, 8 members have posted to it.
2815 guests, 162 members online
