Thread started 26 Apr 2007 (Thursday) 16:11
Male Pheasent -
Pete ­ W
Gallery: 44 photos
Apr 26, 2007 16:11 |  #1
Hi All.... Novice photographer and Photoshop user...
Took this picture this morning in my back garden... feedback appreciated... I have broad shoulders..........
Equipment Canon 30D, Sigma BIGMA, @ 500 f7.1 400thSec ISO200. RAW
CS3 Photoshop used to tweak values.
All the best
Pete Woods LRPS QGP ASINWP
My Website (external link)
canonloader
Gallery: 6 photos
Apr 26, 2007 16:34 |  #2
Very nice shot. But it looks just a little soft. I've had good results sharpening these up by opening the jpg in CS2, then go to the Channels Pallet. Click on the Blue Channel layer to select it, look at the image for sharpness. Click in the channel name area. Then do the Green and Red layers. You will find that one of the channels will be more blurred than the others. Select that color layer then go to Filters/Sharpen Edges. Then click the RGB layer and look at the image again. That will usually sharpen it up nice. You may have to do the same to the next most blurred layer though, but I haven't had to do that often.
Mitch- ____...^.^...____
Lame-Duck
I have indeed had pine nuts
Gallery: 1251 photos
Apr 26, 2007 17:03 |  #3
Peter....Nice shot of the pheasant. I like the lighting and the color you got. I'd say, that as a novice, you are off to an excellet start.
Mitch.....Thanks for the sharpening tip.....it is most helpful.
LD, or Mike
Often mistaken, but never in doubt.
Pete ­ W
Gallery: 44 photos
Apr 27, 2007 00:19 |  #4
Thanks guys..... Any and all feedback much appreciated
All the best
Pete ­ W
Gallery: 44 photos
Apr 27, 2007 00:30 |  #5
Mitch
Had a go at what you suggested...
All the best
canonloader
Gallery: 6 photos
Apr 27, 2007 00:42 |  #6
Which channel did you use? That might be a bit too sharp. If it comes out too sharp, you can use Edit/Fade to tone it down a bit, but you have to use fade as the very next step or it greys out. It's definately sharper though.
Pete ­ W
Gallery: 44 photos
Apr 27, 2007 00:55 |  #7
That was sharpening Blue & Green
This is just Blue
All the best
Pete ­ W
Gallery: 44 photos
Apr 27, 2007 00:57 |  #8
This is just Green
All the best
canonloader
Gallery: 6 photos
Apr 27, 2007 09:07 |  #9
I think the green one looks best.
Pete ­ W
Gallery: 44 photos
Apr 27, 2007 09:34 |  #10
Thanks Mitch.... Info like this will help me improve.....
All the best
pknight
Gallery: 39 photos
Joined Feb 2006
Apr 27, 2007 09:52 as a reply to  @ Pete W's post |  #11
I like the Pheasant shot. Around here you typically only see their heads in the long grass.
Mitch, thanks for the sharpening tip. Do you find that this works subtantially better than the filters built into PS?
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
1,460 views & 0 likes for this thread, 4 members have posted to it.
Male Pheasent -
1598 guests, 139 members online
