Does anyone have a collection of cloud/horizon shots that you wouldn't mind if I borrowed your clouds? I'm trying to salvage a picture with a blown out sky. I was thinking I could layer over in PS.
newton Senior Member 568 posts Joined Mar 2007 Location: Houston, TX More info | Apr 26, 2007 20:17 | #1 Does anyone have a collection of cloud/horizon shots that you wouldn't mind if I borrowed your clouds? I'm trying to salvage a picture with a blown out sky. I was thinking I could layer over in PS.
Zepher Goldmember 1,626 posts Likes: 1 Joined Nov 2005 Location: Norfolk,VA More info | Apr 26, 2007 20:21 | #2 Here is a shot you might be able to use, Manny Desantos
Probably need much greater FOD.
Zepher Goldmember 1,626 posts Likes: 1 Joined Nov 2005 Location: Norfolk,VA More info | Apr 26, 2007 20:29 | #4 almost any shot is fixable, just depends on the amount of time you want to take. Manny Desantos
Zepher Goldmember 1,626 posts Likes: 1 Joined Nov 2005 Location: Norfolk,VA More info | Apr 26, 2007 20:43 | #5 Quickie edit using one of my images. The image I used is in the folder above. Manny Desantos
Apr 26, 2007 20:49 | #6 Amazing! Do you mind if I use those clouds? I will redo them on a larger version of the image.
Zepher Goldmember 1,626 posts Likes: 1 Joined Nov 2005 Location: Norfolk,VA More info | Apr 26, 2007 20:50 | #7 I don't mind. go right ahead, just let us see how it turns out. Manny Desantos
Which image is it in the folder?
Zepher Goldmember 1,626 posts Likes: 1 Joined Nov 2005 Location: Norfolk,VA More info | Apr 26, 2007 20:56 | #9 IMG_2263.jpg Manny Desantos
ed. Goldmember 2,978 posts Joined Oct 2006 Location: 2114.syd.nsw.au More info | Apr 26, 2007 21:06 | #10 EDIT: opps... replied too late. http://www.edwardhor.com
Apr 26, 2007 21:41 | #11 I can't do what Zepher did. I tried layers, but it didn't come out nearly as nice.
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | I did the attached in a couple of minutes. I have a few hundred different cloud shots that I keep handy for backgrounds. My life is like one big RAW file....way too much post processing needed.
lnterestlng Senior Member 393 posts Likes: 1 Joined Apr 2005 Location: Manhattan More info | Apr 27, 2007 08:31 | #13 I understand why you might want to put a sky in there but I would leave it alone. I like the negative white space. It's an advertiser's dream. You could put some copy up in there and make an AD out of it. It's a great image.
SWPhotoImaging Goldmember 3,231 posts Joined Nov 2003 Location: No. Calif. More info | Apr 27, 2007 09:23 | #14 I don't know if that particular shot needs them, but doing a sky replacement is a good reason to start collecting a variety of cloud shots. SWPhoto-Imaging
Apr 27, 2007 10:45 | #15 smdevo wrote in post #3112942 I understand why you might want to put a sky in there but I would leave it alone. I like the negative white space. It's an advertiser's dream. You could put some copy up in there and make an AD out of it. It's a great image. Wow, thanks for the comments. I'm just a beginner. That shot really could have used a ND filter imo.
| Latest registered member was a spammer, and banned as such! 2808 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
