Thread started 29 Apr 2007 (Sunday) 19:02
Printing 8x10's
canon ­ shooter
Apr 29, 2007 19:02 |  #1
What am I doing wrong. I shot wedding and uploaded pictures to lab for print and notice the crop on 8x10 is really cutting the picture short.
What do I have to do get get the full frame to print??
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
jorj7
Apr 29, 2007 19:07 |  #2
Jim,
If you took images straight from the camera, they would print proportionally correctly
at 8x12. If you want to print 8x10 then you probably should crop (and maybe resize)
them to 2400x3200 pixels (or what ever the dpi of the printer is times 8x10 ).
George - SF Bay Area- 1D, 1Dmk2, 20D, 60D, 650D, 6D, 7Dmk2
Ls:16-35,24-70,24-105,70-200,100-400,135,300,400,500
Others: 10-22, 17-55IS, 35, 50, 85, 100 Macro
Peleng8;Sigma14,20,18-250,600,800;Tamron17-50,180, Tokina 11-16
http://birds.avianist.​com (external link)
canon ­ shooter
Apr 29, 2007 19:11 |  #3
jorj7 wrote in post #3125162 (external link)
Jim,
George, sounds like there is a way to save and print at 8x10?
Can you give me more on how to crop them so when I upload to lab they will print close to full frame at 8x10
Jim
Dchemist
Joined Sep 2003
Apr 29, 2007 19:32 as a reply to  @ canon shooter's post |  #4
If you want your image on an 8x10 you have to set the image size to 6x9 or crop it to 6x9 (at 300dpi) - which will include all your image - and then set the canvass size to 8x10. You will get back an 8x10 print with your full image centered and white borders around the outsize. I find this looks okay. You could also set the image size to 6.667x10 and then the canvass to 8x10 and you get rid of the borders on the long axis. Good luck, Dennis
POTN Book Vol4 Astronomy Image Manager and BC Member
20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX
canon ­ shooter
Apr 29, 2007 21:39 |  #5
Prrinting in 8x10
I guess I am really missing something???
I look at other Wedding pictures on this site and others and they are all pretty much framed close. As I did with my shots (See attached).
But when I go to send to lab to print 8x10's they are cropping too much of the image off.
How do you get around this. If I leave a lot more and customer printed some as 4x6 or 5x7 they would have to be cropped to get excess out.
Jim
goforphoto
Apr 29, 2007 21:40 as a reply to  @ canon shooter's post |  #6
You should crop the image to the desired crop before sending the image file to the lab.
Just another shutterbug.
I am not a photographer, I'm an image capture technician.
Canon 40D - 70-200L f4, 28-135 IS, Nifty Fifty, 70-300 macro, 18-55 420EX Sunpak 266d
canon ­ shooter
Apr 29, 2007 21:42 |  #7
goforphoto wrote in post #3125937 (external link)
I have been trying to do that. Can you tell me how to do that in CS2?
Jim
SuzyView
Apr 29, 2007 21:44 as a reply to  @ canon shooter's post |  #8
All files taken on the dslr's give you the 2x3 ratio. If you want the 8x10's then the lab will take off 1 inch on each side of what you sent at 8x12. So you will get a lot of cropping. The 2x3 ratio also does not work for the 5x7 images. Less than an inch would be cropped off of those from the originals as well. So, the advice about sending the crop you need is true. Just do some PP, crop the pictures and save them with a tag that says 8x10, or 5x7 to make sure they are saved in the cropped that you sent to the lab. If you don't prepare the images, the lab does whatever it wants and sometimes, it just does whatever and you're stuck with some really badly cropped work.
SuzyView
Apr 29, 2007 21:50 as a reply to  @ canon shooter's post |  #9
My procedure is the following in PSE 5.0, and I can't imagine it's that much different than CS2.
Bring up your image, Crop it as best you can to make it the ratio you need (2x3, 4x5, 5x7), click on the top bar "Image" and you will see "resize image" or "Image size". Choose that and then decide what resolution you need (I use 600 most of the time), then adjust the height and width to the proper measurement. Read the manual for your CS2 to see how to crop as well. That will really help you the most.
*Mike*
Apr 29, 2007 21:51 as a reply to  @ canon shooter's post |  #10
Use the crop tool in CS2. Put your settings at 8x 10 and dpi at 250 or higher (depending on your lab). Ideally, if you know a print will be in a 5x7 format or 8x10 - you'll have to leave room for cropping when you shoot the image. In other words, you need to leave some dead space to get the image to crop the way you want. A way around the 4x6's looking silly - don't offer that size. The smallest size we offer is 8x10 for the purchase of a solo print. If they order a package it might have 5x7's since grandparents tend to ask for that size. No one has whined about us not offering the 4x6 size. We push large prints, so that could be why. But a little planning goes a long way. And if you crop all your own stuff - which is REALLY easy - you can control it to your liking and not worry about the printer.
Belle's Photography (external link)* Belle's Blog (external link) * Belle's MySpace (external link)
canon ­ shooter
Apr 29, 2007 21:55 |  #11
SuzyView wrote in post #3125958 (external link)
Is there a way to do this and still get the full frame of what was taken?
And how do you avoid cropping unwanted subject or if other sizes are printed leaving too much on the edges
Jim
canon ­ shooter
Apr 29, 2007 21:58 as a reply to  @ canon shooter's post |  #12
I know 8x12 are full frame, but what does anyone do with a 8x12. Most of the album pages are 8x10, and I have never seen an 8x12 frame
Jim
canon ­ shooter
Apr 29, 2007 21:59 |  #13
*Mike* wrote in post #3125994 (external link)
I don't mean to be a pest, but trying to get the best out of them.
When you use the crop tool and set at 8x10 then do you select the entire image with the crop tool?
Jim
SuzyView
Apr 29, 2007 22:10 |  #14
canon shooter wrote in post #3126035 (external link)
I have purchased pre-made frames that are 8x12, but really, if you can cut mats, you can cut to whatever you need for the best image presentation. Most standard mats are for 8x10, 11x14, etc. So, you have to special order or cut the mats and order the frames to support the 8x12 images. I find it easier to do exactly what is suggested above and zoom out a little and allow the sides to have extra and then crop to 8x10. That way you don't have to buy expensive frames and mats. Once in a while I'll go to a frame store and buy the metal or wood frames that you buy the length separate from the width and use those for my 8x12's without mats. I've only had to do that twice.
canon ­ shooter
Apr 29, 2007 22:30 |  #15
IS this ratio the same for Digital P&S and 35MM film
Jim
3,418 views & 0 likes for this thread, 10 members have posted to it.
Printing 8x10's
2815 guests, 162 members online
