2005GLI wrote in post #3129211
But it answers my question that it can't be done.
There are other ways to remove the "bulging in the middle" effect. One way is to shoot at a 50mm plus focal length which will reduce the effect. 80mm to me is best as it will give you a natural line of sight.
The other way if shooting below 50mm is to try the fish eye lens correction trick: You basically distort your end result to correct the "fish eye" effect you got after blending.
This approach has many pitfalls, namely:
1) The left and right sides become stretched
2) The middle becomes squashed
3) You lose top and bottom detail
But a way around the problems
is to do two panos, half and half of the scene. Do the fish eye correction and then merge the two panos, after correction, together.
You may also want to do a muli-row pano because of the detail you lose at the top and bottom. Always shoot in portrait when doing a pano.
This is an example of a one-step pano being corrected. If this was three separate panos, I could correct with much less of a distortion and then blend the three panos together.
Make sense?
