Thread started 30 Apr 2007 (Monday) 04:11
ZB Ex: Rotate and Actual Rotate Images
TomPhotog
Apr 30, 2007 04:11 |  #1
What is the functional difference between Rotating an image using the EXIF data and Rotate Actual Image?
PacAce
Joined Feb 2003
Apr 30, 2007 11:25 |  #2
When an image is rotated via a tag in the Exif info, the image isn't physically altered to achieve the rotation. It's the browser program that recognizes this tag that actually rotates the image for you. If you use a browser that doesn't recognize the tag, the image is displayed as-is, unrotated.
If you opt to "Rotate Actual Image", the image file is changed so that the image is rotated and will display way that no matter what browser you use to view the image.
BTW, by "browser" I mean any image viewer and not necessarily an internet browser. :)
...Leo
Sergio ­ Carvalho
Apr 30, 2007 12:43 |  #3
I have a related question.
I know some editors/viewers may do a bad job and loose image quality when rotating. Windows Picture and Fax Viewer is particularly bad, usually using more JPEG compression than the original file (and therefore introducing more JPEG artifacts).
How bad is PS Elements Organizer's rotating feature in this respect? Should we worry about it?
I've just tested it and noticed that files get smaller, so I guess there is also some loss going on...
Sergio ­ Carvalho
May 01, 2007 08:19 |  #4
I did some research and guess I find the answer for my own question... just in case someone wants to know:
"Most images will not lose quality when rotated 90 or 180 degrees. JPEG is the exception because of the way this format is compressed. Some programs can do lossless JPEG rotation, but it is unclear whether Photoshop is one of them."
Source:
http://graphicssoft.ab​out.com …aging/f/rotateq​uality.htm (external link)
"(...) it is possible to do 90-degree rotations and flips losslessly, if the image dimensions are a multiple of the file's block size (typically 16x16, 16x8, or 8x8 pixels for color JPEGs)."
Source:
http://clk.about.com …Dfaq%2Fpart1%2F​index.html (external link)
JPEGclub.org provides a list of applications which provide the JPEG lossless rotation feature. Incidentally, Photoshop is not on it.
http://clk.about.com …gcrop%2Flossles​sapps.html (external link)
Canon's zoombrowser can also "simulate" rotation by setting a flag in the EXIF data. That, of course, does not incur in any loss of information, but if your viewer doesn't support EXIF, you won't see the rotated image.
Graystar
May 01, 2007 08:56 as a reply to  @ Sergio Carvalho's post |  #5
removed
Sergio ­ Carvalho
May 02, 2007 03:27 |  #6
Correction:
Photoshop does lossless JPEG rotatation whenever possible. If it's not possible, you get a warning.
1,367 views & 0 likes for this thread, 4 members have posted to it.
2714 guests, 168 members online
