Thread started 30 Apr 2007 (Monday) 20:59
Background Too Bright
portraitsbytracy
Apr 30, 2007 20:59 |  #1
How do I go about reducing the brightness of this background? I tried masking off the face and adjusting levels, curves, etc., but it didn't do anything. I realize I also got a little too much spill on this high key attempt. Any suggestions for corrections?
tim
Light Bringer
May 01, 2007 00:46 |  #2
It's out of focus so there's no point messing around with it. It would've been a nice shot. Background looks fine to me.
Nursedad
May 01, 2007 05:40 |  #3
There are probably a ton of ways to do this, but here's one that I quickly thought of:
- Select your subject and make a new layer (cmd or ctrl j) with this selection
- Above your original layer, add a color adjustment layer (choose a light to medium gray)
- Above this layer, add a levels adjustment layer and drop your shadows slider to make things look slightly darker than you would like
- Finally, reduce the opacity of your color adjustment layer until you get the look you like.
Like I said, probably several ways to do this.
Best of luck...
- - Jeff
Rebel XTi / 18-55 Stock Lens / Tamron 17-50mm 2.8
580ex II Speedlight / Aperture / Photoshop CS3
portraitsbytracy
May 01, 2007 21:44 as a reply to  @ Nursedad's post |  #4
First of all, Tim, I agree with your quote "grumpy old bastard in training."
Second, thank you Nursedad, for taking the time to make the necessary adjustments. I'll try the layers, I'm quite the novice when it comes to PS, so I'll have to play around with the steps that you took to achieve the toned down background.
bagtagsell
May 02, 2007 00:04 |  #5
I would use the pen tool to extract the boy onto a new layer. Then you can adjust the layer without effecting the boy. Maybe auto color/level/contrast. If it isn't there yet tweak each of those settings manually.
Mark Ryan Photography (external link)
RodBarker
May 02, 2007 07:45 |  #6
bagtagsell wrote in post #3137950 (external link)
Pen tool is not a good method for cutting out a clean mask ! takes to long on intricate areas like hair and will never give you really good mask .
Rod
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 02, 2007 09:10 |  #7
It's a PITA unless you take the time to learn it AND use it all the time so you don't forget the little tricks.
I wouldn't change the brightness of the background & prefer the white to the gray. The problem is the spill on the face, & I'd fix it with a Layer Mask: It's easily reversible: Airport runway shoot
More detailed methods:
Mixed Lighting Issues Solved By Using RAW Format!!!
RAitch Tutorial - Burn and Dodge with a Layer
Some links at the bottom of this thread may help:
Mustang & B-17 + PS
1,642 views & 0 likes for this thread, 6 members have posted to it.
2718 guests, 167 members online
