Apologies if this is covered elsewhere but a search provided not useful info.
I have a photo with an OK foreground and an over exposed background. I understand that there is a technique that can be used with 2 RAW conversions (one for background and one for foreground) so that you get the best of both worlds. I was once shown how to do this in CS2 but now I only have Elements 5 so the instructions don't work due to the lack of the "Add layer mask" option.
Could anyone talk me through how to do this in PE5 or point me at a tutorial?
Thanks in advance.
), and choose a size of several hundred pixels, the actual size you want will depend on size (pixel-wise) of the shot. Make sure the "hardness" is set to a low number (I use zero). Set the opacity for 50%, but experiment with this value to find what works for you.
