Thread started 01 May 2004 (Saturday) 21:54
How to spilt the cases on a A40??
Hip2u77
Joined May 2004
May 01, 2004 21:54 |  #1
Hi, Girlfriend had her A40 unprotected in her purse and some type of hair gel or something got on the selector knob and now it's froze. How do I get it apart to clean it. I'm very mechanically inclined but it seems theres some screw or something up by the shutter/zoom button area that won't allow it to open up. I don't see any screws inside the battery or CF slot. Am I missing one or is it just stuck because of the hair stuff?
Thanks a bunch.
Shawn
EoSD30fReAk
Joined Aug 2003
May 02, 2004 03:17 |  #2
there are 2 srews on both sides and three at the bottom
then open the cf door and you should get the backcover of pretty easy
you have to start opening it from the bottom.
if not it is probably full with the sticky stuff 8)
Photography is my way to relax
Conk
Joined Jul 2002
May 02, 2004 10:58 |  #3
May I suggest buying a can of contact cleaner before opening it up.
Cloverdale Photography (external link)
Photos (external link)
More Photos (external link)
Hip2u77
Joined May 2004
May 02, 2004 15:47 |  #4
Already had tried contact cleaner. It works for about 5 minutes at a time. once the cleaner evaporates it's hard to turn again.
PS. Still haven't got it apart. Still feels like there something holding it together around the shutter button. Even using a jewelers screwdriver to try and "pry" the case apart won't budge it.
I've got 7 screws removed.
I'm stumped. ?!
Conk
Joined Jul 2002
May 02, 2004 17:05 |  #5
I'm stumped. ?!
Ok then, so when you spray it with contact cleaner and it does in fact work up until it evaporates then try a light silicone spray as a lube. I personally wouldn't be too worried about it getting inside the camera.
It has been mentioned by many people, including myself on this forum about the dial being stiff on the A40. Yours happens to be sticking more than the usual.
Hip2u77
Joined May 2004
May 03, 2004 03:33 |  #6
Thanks for all the help everyone. The case had gel on it also and that's why it wasn't opening easily. I had to pry it open while pressing down in the area where the top tab holds it together.
I posted a "How To" for everyone to explain how to fix the sticky knobs on the A40's.
Shawn
1,930 views & 0 likes for this thread, 3 members have posted to it.
1253 guests, 123 members online
