fi20100 wrote in post #3143805
Well, the hood that I got in the box for the 17-40L, does not do much to help with flare when the lens is mounted on my 350D. But I'll keep it for the future
My point, exactly!
As for the EW-83J on 17-40...
...on a FF camera (5D) the 17-40 hood is meant to cover the 33-70 degree angle of view of the 17-40 lens.
...on an APS-C camera the 17-55 hood is meant to cover the 16-48 degree angle of view of the 17-55 lens.
If the 17-55 hood is used on a 17-40 lens mounted on an APS-C camera, it was designed for a narrow AOV range so things are generally fine.
But if the 17-55 hood is used on a 17-40 lens mounted on a FF camera, hood cutoff of the image occurs from about 50-70 degree AOV because it is designed for a more narrow FOV.
And if the 17-40 hood is used on a 17-40 or 17-55mm lens mounted on an APS-C camera, the hood was designed for a wide AOV so it does not afford the degree of protection it should, as is noted by fi20100. It works, yes; it doesn't do as good a job as it should!
