Thread started 03 May 2007 (Thursday) 01:05
2 Memory Cards, conflicting filenames
PhilN
May 03, 2007 01:05 |  #1
So now I have two bodies and two cards, but the file names will conflict. The new card started at _8449, so I reset the old to 0001, but at some point Im going to get conflict.
How do you get round this? I presume Im going to have to batch rename somehow?
Experience is something you get after you need it.
5D+Grip, 24-105L, 17-40 L, 100-400 L, 400D+grip, EFS17-85 IS, EFS17-55IS, EFS60Macro, EF70-300IS, EFS10-22, 580EX2 flash, Manfrotto 190ProB & Ballhead. Plus a bunch of bits.
http://www.philnortonp​hotography.co.uk (external link)
TeeJay
Joined Jun 2005
May 03, 2007 01:39 |  #2
What software do you use to import/organise your images. Most will allow you to rename as you ingest them to your hard drive.
I'm not farmiliar with the 5D, but does it not have a method of changing the "prefix" used on images?
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
René ­ Damkot
May 03, 2007 02:29 |  #3
Here is a thread with the same question, and answers...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
In2Photos
May 03, 2007 08:12 as a reply to  @ René Damkot's post |  #4
Since Rene already gave you the answer I will only add that since you use Lightroom you should rename during Import. It is very easy to do and you can setup presets. I only have one camera but still rename all my files becasue at 10,000 shots the numbers start over again (IMG_0001 is the same for shot #1 and shot #10,001, #20,001, etc.). I use the date and filename, like 2007_05_03__MG_1219.DN​G.
Current Gear and Feedback
PhilN
May 03, 2007 13:31 |  #5
In2Photos wrote in post #3144706 (external link)
guys thanks very much I figured it out. Im finding it fairly easy to rename from DPP, and then dump them in watched folder. Still finding LR a little tricky and also that I prefer DPP for processing sometimes, but getting there. LR so far is superb for management.
796 views & 0 likes for this thread, 4 members have posted to it.
2715 guests, 167 members online
