Thread started 04 May 2007 (Friday) 05:58
PP workflow help!
totalbeginner
May 04, 2007 05:58 |  #1
I'm thinking that my workflow is rather cumbersome. Maybe this is due to the programs that I'm using, or maybe I'm missing something. It just seems to take ages.
It goes something like this....
(1) Open RAW's in DPP
(2) Choose recipe, adjust, copy etc...
(3) Batch process to output file.
(4) Open in PS
(5) Tweak levels, saturation etc...
(6) Resize / Crop if needed
(7) Re-save
8. Sharpen for printing or after re-sizing for web.
Can any of this be speeded up? The longest job of the lot, is going through the files in photoshop and sharpening them. 20 or so images and it takes me over an hour :(
View my gear list HERE
Don't submit to stupid rules, be yourself and not a fool. Don't accept average habits, open your heart and PUSH THE LIMITS!
In2Photos
May 04, 2007 07:18 |  #2
I think that is a pretty standard workflow. One thing that would speed you up is batching your shaprpening (if you have images that require the same amount of sharpening).
This used to be my workflow as well until I picked up Lightroom. Now I only export from Lightroom to CS2 for sharpening (which I run from a droplet) or if I am choosing to do some major work on an image.
Current Gear and Feedback
Bollan
May 04, 2007 07:23 |  #3
I was in your boat as well and the answer for me was Adobe Lightroom.
In LR i do 95% of all the adjustments i need to do to my pictures. Its great for
batch processing and the file management is very good. Of course if you do want
to do more advanced work on your pictures you will find that you need to spend
some more time in PS. But for a fast and very efficient way of managing your daily workflow LR is great.
The only thing you would need PS for is for the sharpening process.
The good thing is that the sharpening can be automatized from LR by
creating an action in PS. Just save it as droplet and include it in the final
export steps for LR to use.
My Equestrian Gallery (external link)
My Flickr (external link)
totalbeginner
May 04, 2007 07:33 as a reply to  @ Bollan's post |  #4
Funny you should mention lightroom, I ordered it last week and should be arriving soon.
When I've converted my RAW, I like to save the file (hi res) unsharp. This enables re-sizing of the file at any time and then I can apply sufficient sharpening. This is good for landscapes, but it's a pain for potraits. Normally I use selective sharpening for portraits (eyes etc..) which has to be done every time I resize or want to print.
Is there any way around this?
In2Photos
May 04, 2007 07:37 |  #5
totalbeginner wrote in post #3149927 (external link)
With Lightroom you wouldn't have to "Save" the unsahrpened file. Your RAW file, along with the Lightroom database will keep the file as is. Then when you need a copy of it for a specific purpose you can export (resizing here or in PS) and sharpen for output.
Currently the sharpening in Lightroom is very limited. Until they correct that you will still have to use your current method for selective sharpening of portraits. Update 1.1 is supposedly going to have better sharpening capabilities and eventually when third party software is available hopefully there will be no need to sharpen in another application.
gardenstate
May 04, 2007 07:46 as a reply to  @ In2Photos's post |  #6
Although I primarily shoot/PP JPG format photos, you can also use my favorite batch processing software (DCE Autoenhance) with RAW format. It is just great, inexpensive, and really adds "pop" to the images.
DCE Autoenhance
http://www.mediachance​.com/dce/index.html (external link)
some of its features:
Automatic Balance
Remove Blue Cast
Adjust Mid-tones
Enhance Colors
Enhance Details
Remove Hot Pixels
De-noise the image.
Portrait De-Focus Filter
Resize the image
Finds the JPG quality for each image according your needs
Add a text or Exif data such a date of shot taken, shutter speed, ISO etc. into the image with great control about the colors and parameters
Duplicates source folder structure for output images
Color Match Minolta DiMAGE files to sRGB
totalbeginner
May 04, 2007 07:50 as a reply to  @ In2Photos's post |  #7
Not sure I understand?
Are you saying that when you make adjustments in lightroom, the RAW file remains unchanged but is kind of tagged with the details of the corrections that you have made?
Does this mean that you can change them at any time without saving another copy?
S.Horton
May 04, 2007 07:54 |  #8
gardenstate wrote in post #3149974 (external link)
DCE Autoenhance
Automatic Balance
Remove Blue Cast
Adjust Mid-tones
Enhance Colors
Enhance Details
Remove Hot Pixels
De-noise the image.
Resize the image
This is interesting, as I'm about to post a question about color correction in batch....... Can you post a link to your results using this software?
Sam - TF Says Ishmael
:cool:
In2Photos
May 04, 2007 07:57 |  #9
totalbeginner wrote in post #3149985 (external link)
Correct. RAW files are never changed. Rather they have a file or a database that stores the changes you have made to the RAW. So you never have to "save" a file like you do with a jpeg. If you want multiple images with different changes you simply create a Virtual Copy of the original and make different changes. For example, let's say that I have an image that I want to adjust and have both a color and a B&W image. I import the RAW file, make adjustment that I want to apply to both images to the original. Then I create a Virtual Copy and make additional enhancements for the color one, and an additional Virtual Copy and make additional enhancements for the B&W one. Now, my HD still only has one Image file, but I have a database that contains the changes made to the three images. Pretty slick, huh?:)
totalbeginner
May 04, 2007 08:00 as a reply to  @ In2Photos's post |  #10
Correct. RAW files are never changed. Rather they have a file or a database that stores the changes you have made to the RAW. So you never have to "save" a file like you do with a jpeg. If you want multiple images with different changes you simply create a Virtual Copy of the original and make different changes. For example, let's say that I have an image that I want to adjust and have both a color and a B&W image. I import the RAW file, make adjustment that I want to apply to both images to the original. Then I create a Virtual Copy and make additional enhancements for the color one, and an additional Virtual Copy and make additional enhancements for the B&W one. Now, my HD still only has one Image file, but I have a database that contains the changes made to the three images. Pretty slick, huh?:smile:
Wow! that's going to make a big difference for me! I currently have duplicate files for most images; the raw file and a converted high res JPEG. This will save so much faff, and wasted space!
1,854 views & 0 likes for this thread, 5 members have posted to it.
PP workflow help!
2844 guests, 164 members online
