If I had a few busck to spend on a lens, the "L" serises is out right now, which is the better of the two, a cannon Ef or EF-S lens. I have a 28-80 EF and a 18-55 EF-S. I use the 18-55 mostly. Which is the better of the 2. Thanks
Hulka Senior Member 378 posts Likes: 1 Joined Jan 2007 Location: Laveen, Az More info | May 04, 2007 23:43 | #1 If I had a few busck to spend on a lens, the "L" serises is out right now, which is the better of the two, a cannon Ef or EF-S lens. I have a 28-80 EF and a 18-55 EF-S. I use the 18-55 mostly. Which is the better of the 2. Thanks http://www.flickr.com/photos/61517977@N03/
DerekI Senior Member 752 posts Joined Feb 2007 Location: Chiang Mai . More info | May 04, 2007 23:59 | #2 Hulka wrote in post #3154072 If I had a few busck to spend on a lens, the "L" serises is out right now, which is the better of the two, a cannon Ef or EF-S lens. I have a 28-80 EF and a 18-55 EF-S. I use the 18-55 mostly. Which is the better of the 2. Thanks it is easy , I know this 28-80 is about 10 years old and designated for film rebels. Canon EOS40D(2).
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | May 05, 2007 00:02 | #3 They both suck. But the 18-55 is less sucky. Did you lose Digital Photo Professional (DPP)? Get it here
EORI Senior Member More info | Don't let the negative comments about the 18-55 kit lens bother you. It's an ideal starter lens for someone new to photography, as it gives you enough wide angle, and sufficient telephoto range, to cover most of your shooting needs.
_aravena isn't this answer a stickie yet? 12,458 posts Likes: 12 Joined Feb 2007 Location: Back in the 757 More info | May 05, 2007 00:25 | #5 ^Definitely. By no means is the kit lens sucky. Great description by the way. Last Shot Photography
fWord Goldmember 2,637 posts Likes: 1 Joined Jan 2006 Location: Melbourne, Australia More info | In terms of optical quality they might both be on about the same level. But given that the 28-80mm (depending on which version you have) is at least 7 years old, the new 18-55mm will probably have the edge. LightWorks Portfolio
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | May 05, 2007 01:31 | #7 EORI wrote in post #3154175 Don't let the negative comments about the 18-55 kit lens bother you. It's an ideal starter lens for someone new to photography, as it gives you enough wide angle, and sufficient telephoto range, to cover most of your shooting needs. To see what this lens is capable of in the hands of an experienced photographer, take a look at some of the images in this thread: https://photography-on-the.net …?t=185522&highlight=18-55 Everything looks good at web resolution and/or f/8. Did you lose Digital Photo Professional (DPP)? Get it here
DerekI Senior Member 752 posts Joined Feb 2007 Location: Chiang Mai . More info | May 05, 2007 01:38 | #8 cdifoto wrote in post #3154157 They both suck. But the 18-55 is less sucky. yeah , it's a great answer. Canon EOS40D(2).
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | May 05, 2007 01:40 | #9 Sorry if I was too technical. Sometimes I get carried away... Did you lose Digital Photo Professional (DPP)? Get it here
fWord Goldmember 2,637 posts Likes: 1 Joined Jan 2006 Location: Melbourne, Australia More info | May 05, 2007 01:49 | #10 As they always say in photography, 'less is more'. In this case very few words may still be overflowing with meaning. LightWorks Portfolio
That is what I currently have at this time. I would like to upgrade to a better lenses. If I have to sell all 3 to buy 1 decent one then so be. I keep hearing that the 50 Macro , nifty fifty, is a great lens and I might look at one of those. I use the 18-55 mostly. I guess I should just save and get a "L" lens in that range. http://www.flickr.com/photos/61517977@N03/
liza Cream of the Crop 11,386 posts Likes: 1 Joined Feb 2005 Location: Mayberry More info | May 06, 2007 23:54 | #12 Permanent banThe Tamron 17-50, as has already been recommended, is probably the best bang for your buck. The range, constant aperture, and image quality are all great.
DerekI Senior Member 752 posts Joined Feb 2007 Location: Chiang Mai . More info | May 07, 2007 01:01 | #13 And the Tamron built like a tank. Canon EOS40D(2).
OK how is that new one they have out, that goes to like 200? Worth getting? http://www.flickr.com/photos/61517977@N03/
| Latest registered member is MWCarlsson 862 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
