Thread started 05 May 2007 (Saturday) 00:41
Power of Multiples, 2=1 or 4=1
dfindr
May 05, 2007 00:41 |  #1
If 2 AB 400's are fired simultaniously at full power does the output equal that of 1 AB 800 fired at full power?
If 4 AB 400's are fired simultaniously at full power does the output equal that of 1 AB 1600 fired at full power?
If the answer to this quesion is yes than If 2 AB 800's are filed simultaniously at full power than it would equal that of 1AB 1600 fired at full power> True?
DAVID ALAN DARBY // MAC CONVERT // Raging and unapologetic L'coholic constantly Striving To Measure Up to the Quality of My Gear!
Too Many Bodies, Way Too Much Glass, Not Enough Time . . . BUY THE BEST, BUY IT ONCE, GO TAKE PICTURES!
awad
May 05, 2007 01:31 |  #2
whoa. trippy.
http://www.redfieldpho​to.com (external link)
http://www.theredfield​blog.com (external link)
disneydork06
May 05, 2007 02:01 |  #3
just guessing here but the entire output should be equal. but what's the point since they will prolly be point at different spots at different locations. so you're not really dealing with that ab800, just in total output. it would be kinda hard to have them on the same exact plane, same exact location, and same exact angle...right?
Ryan
~AZ POTN Planned Activities (external link)
let me know how I can improve, cause we all know I need it :): Flickr (external link)
myspace (external link) facebook (external link) The Greatest online forum known on Earthtwitter (external link)[URL="http://www.500px​.com/RDimal"]500xp follow me! in something^ you know you want to
TeeJay
Joined Jun 2005
May 05, 2007 02:33 |  #4
Assuming the maths stacks up it should, but it wouldn't be anyway as near effective as having separate, individually controllable heads, that can be positioned to direct the light onto the subject from different angles.
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
steveathome
Gallery: 19 photos
May 05, 2007 09:55 |  #5
At risk of giving wrong information, answer deleted
René ­ Damkot
May 05, 2007 09:57 |  #6
dfindr wrote in post #3154278 (external link)
True.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Wilt
May 05, 2007 10:08 |  #7
Yes, if all the lights were all together and aimed at one position. It is common for professional studio strobe heads to come in a 'bi-tube' or 'quad-tube' configuration where all the flash tubes are together in a single head. the Bitube is double a single tube in power, and the quadtube is 4x a single tube in power. (BTW, each tube is powered from a different source...if 4 tubes were powered from a single capacitor, they would merely divide the available power between them, and collectively only be about a single tube in output!) Since AB are monolights rather than pack + heads, it is simple...the lights are all additivie, as you surmised.
1,114 views & 0 likes for this thread, 7 members have posted to it.
1241 guests, 164 members online
