Thread started 05 May 2007 (Saturday) 11:17
How do you change the opacity of a layer mask?
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
May 05, 2007 11:17 |  #1
I've created some complicated masks using black. I now want to change the opacity of the mask so it behaves like a grey, nog black. I do not want to change the opacity of the layer the mask is on, only the black/white mask itself. How is this done? /Dan
Website (external link) |
René ­ Damkot
May 05, 2007 11:30 |  #2
Click the mask, hit Cmd-L (levels), adjust the black point to make the black 'gray'. It will then show more of the layer. You can also tweak the contrast of the mask this way.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
lostdoggy
King Duffus
Joined Aug 2004
May 05, 2007 11:32 |  #3
interesting got to try that!!!
Gaaaaa! DOH!! Oops!
May 05, 2007 13:40 |  #4
René Damkot wrote in post #3155990 (external link)
VIOLA! Fantastic. Works great. In fact, in addition to adjusting the mask opacity with output levels, I discovered that by adjusting the levels controls on top you can tweak the feathering on the mask edges.
Rene, you always come up with great photoshop answers. I'll bet if I asked you how to use photoshop to design a naqahdah generator to power a starship you'd be able to do it in 3 easy steps. ;)
hannaxt
May 05, 2007 14:07 |  #5
You could also switch from masking with black to a tint say 50% or 40% etc. of gray.
that way if you want to maintain parts with the 100% black and some with just the lower opacity in the same adjustment.
So the same layer mask will have both black and various tints of gray revealing various degrees of the image below the mask.
5DMKII •EF50mm f1.4 •EF85mm f1.8 • EF100mm f/2.8 ISL • EF17-40mm f/4L •EF24-70mm f/2.8L •EF70-200mm f/2.8 ISL
1,121 views & 0 likes for this thread, 4 members have posted to it.
2844 guests, 164 members online
