Thread started 06 May 2007 (Sunday) 04:50
Camera Timer UPDATE
hcker2000
May 06, 2007 04:50 |  #1
Well it has taken longer than I was hoping but thats how life goes some times. In the end I have most of the hardware mounted. Most (99%) of the software finished.
Here are some updated pictures of most of the hardware installed in the case. I still have 3 switches to mount and a jack to install but other than that its all in there.
http://picasaweb.googl​e.com/hcker2000/HNetTi​mer (external link)
Canon EOS 20D, Canon EOS A2
Canon 50mm f1.8, Tamron 28-80mm f3.5-5.6, Tamron 75-300mm f4-5.6
simwells
May 06, 2007 06:38 |  #2
When are you thinking the first one will be totally finished then? I'm definately interested for when you start making more
hcker2000
May 06, 2007 07:23 |  #3
So long as nothing big creeps up I am planing on finishing it up wednesday.
As far as component placement in the case goes I am done with that step. I will need to get a hold of some more of the bolts I use for mounting the lcd and some of the switches.
I have enough components at this point to make one more but getting parts should be fine to make as many as people need.
PacAce
Joined Feb 2003
May 06, 2007 07:51 |  #4
What exactly is this camera timer? Is it something you'd use to trigger a camera and keep the shutter open, in bulb mode, for a certain length of time?
...Leo
hcker2000
May 06, 2007 08:34 as a reply to  @ PacAce's post |  #5
Thats one of the functions. You can use it for things like time laps photograpy, long exposure photograpy, lightning photography with the built in lightning trigger.
You can also triger the timer wirelessly via infared remote (any remote will work).
It also acts as a remote shutter cable when the unit is turned off.
This is the original thread
https://photography-on-the.net/forum/showthre​ad.php?t=180493
simwells
May 06, 2007 09:39 |  #6
Well put me down for one when you start making them as long as your happy sending to the UK
hcker2000
May 07, 2007 01:30 as a reply to  @ simwells's post |  #7
I have never sent any thing over sea's before but I'm sure I can figure it out. ;)
I am thinking of having differnt versions available with and with out the Ir trigger. With and with out the lightning trigger. I know some people may not want/need them.
simwells
May 07, 2007 05:14 |  #8
Yeah that might be an idea well It would depend on pricing but I'd definately want one with an IR trigger, but maybe not the lightning
hcker2000
May 08, 2007 01:41 |  #9
Ok well I will let you know what the difference in price would be once i get it all working.
simwells
May 08, 2007 16:18 |  #10
Do you plan on adding some way it can be attached to items such as a tripod? (hung off central hook on models with one / attached to the legs etc.)
simwells
May 16, 2007 07:18 |  #11
Any news on how you're getting on with your prototype of this?
rmford
May 16, 2007 09:21 |  #12
I think i might have to put my hand up for one as well. Let me know a rough price (your currency or mine, not worried, just lemme know which so i don't calculate twice :lol:). I'd be looking at one with all the bells and whistles, pref with the e3 connector.
Does it still just interact with the digital in/outputs from the camera port? Is there a useable voltage output from that, ie, can you have it powered from the camera? or is that something you've tried and discounted?
EOS 400D (Drebel XTi), 18-55 EF-S, 50mm f/1.8 II, 50mm f/1.4, 75-300mm EF III, BG-E3, 580EXII, Slingshot 200AW, Transcend 4Gb.
http://rmford.devianta​rt.com (external link)
r.morales
May 16, 2007 21:14 |  #13
this might help
http://www.action-electronics.com/audioc​onnectors.htm#Mini (external link)
hcker2000
May 30, 2007 04:35 |  #14
Well after fighting to get the lcd display working I finally got it going. I also fixed 3 bugs along the way.
I still have some testing to do but now that the lcd is working that makes things a lot simpler for me to debug code and hardware.
The connectors do supply some power but trying to use that to power the timer would probably cause the camera to do different things constantly depending on the mode you had it in.
It takes 4 AA batteries right now and I am not sure how long the battery life will be but it should be at minimum 10+ hours with the lcd back light turned off. For people looking to do long time laps stuff I can always put an external power port on it for another battery pack.
simwells
May 30, 2007 04:43 |  #15
So when do you think you'll have the first ones available then?
8,435 views & 0 likes for this thread, 12 members have posted to it.
Camera Timer UPDATE
1745 guests, 171 members online
