I know it's a lame question, but I am a bit confused...
On one site it said the matrix is a size of a fingernail, on the other it says it's the same as 35 mm film.
Please tell me
DocFrankenstein Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | May 03, 2004 20:17 | #1 I know it's a lame question, but I am a bit confused... National Sarcasm Society. Like we need your support.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | May 03, 2004 20:29 | #2 That sensor size is specified in the manual, Major Specifications, Image Size.
cmM Goldmember 5,705 posts Joined Apr 2004 Location: Chicago / San Francisco More info | May 03, 2004 20:46 | #3 22.7mm x 15.1mm
DocFrankenstein THREAD STARTER Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | May 03, 2004 23:16 | #4 DOH - thank you National Sarcasm Society. Like we need your support.
G3 Senior Member 593 posts Likes: 3 Joined Jan 2004 More info | May 03, 2004 23:54 | #5 No. I think the Drebel image sensor is about 40% of the area of a 35mm frame. That results in a 1.6 crop factor when using 35mm lenses. When the image is printed or displayed at the same size as a 35mm frame for the same lens (at the same zoom setting if it's a zoom) that translates to a 1.6 magnification factor. What that means in practical terms is that you will lose substantially on the wide angle end (a 28mm on the Drebel will act like a 45mm would on a 35mm camera), and you will gain substantially on the telephoto end ( a 300mm on the Drebel will act like a 480mm would on a 35mm). There is no change in light transmission, f4 is still f4.
DocFrankenstein THREAD STARTER Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | May 04, 2004 00:08 | #6 But you still lose... kinda National Sarcasm Society. Like we need your support.
cmM Goldmember 5,705 posts Joined Apr 2004 Location: Chicago / San Francisco More info | May 04, 2004 00:29 | #7 Quality ? No
ronchappel Cream of the Crop Honorary Moderator 3,554 posts Joined Sep 2003 Location: Qld ,Australia More info | May 04, 2004 03:41 | #8 Your pictures won't be any darker because the smaller sensor (than 35mm film) just cuts the edges off.The center section that is left is still the same brightness....hope that makes sence
dtrayers Goldmember 1,063 posts Joined Mar 2003 Location: Denmark Township, MN, USA More info | May 04, 2004 06:31 | #9 The amount of light per unit area is the same. -Dave
Andy_T Compensating for his small ... sensor 9,860 posts Likes: 5 Joined Jan 2003 Location: Hannover Germany More info | May 04, 2004 07:10 | #10 ...I know a guy whose fingernails are *exactly* the size of a 35 mm negative... so the answer to your question is 'somehow' some cameras, some lenses,
CoolToolGuy Boosting Ruler Sales 4,175 posts Joined Aug 2003 Location: Maryland, USA More info | May 04, 2004 08:43 | #11 dtrayers wrote: Put another way, you can get the same image quality with a lesser quality lens. That's why the kit lens with the 300D works as well as it does. It doesn't have to make a good image all the way to the edges, just the center. Well, not exactly - the kit lens is designed to produce a smaller image circle than the normal EF lens. It must still be sharp to the edges, but to the edges of a smaller frame (the Drebel sensor). The kit lens is essentially made for a smaller format. Same reason why lenses for a Mamiya 645 are more expensive than those for 35mm. Rick
| Latest registered member was a spammer, and banned as such! 2275 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
