Thread started 06 May 2007 (Sunday) 11:16
CS3 Screen Modes
canon ­ shooter
May 06, 2007 11:16 |  #1
I perfer to have the screen mode set on Standard vs. full. But every time I close a image the next comes up in full. How do I set standard as the default?
In standard you can move images around and decide which one to edit and close others, by seeing more than one image at a time
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
PacAce
Joined Feb 2003
May 06, 2007 17:43 |  #2
Isn't it set to standard screen mode just by clicking on View > Screen Mode > Standard Screen Mode?
...Leo
canon ­ shooter
May 06, 2007 21:48 |  #3
PacAce wrote in post #3161799 (external link)
I like to have in standard mode so I can move the small windows around and compare which ones I might want to edit.
Once I enlarge one to full screen by using the max button the view is changed to full screen mode.
This did not happen in CS2. I could max a image and when I closed it the others would still be there in casaded windows.
Jim
PacAce
Joined Feb 2003
May 06, 2007 22:22 |  #4
canon shooter wrote in post #3162915 (external link)
Oh, I see. Sorry, I can't help since I'm running my CS3 on a Mac and it's behaving the same way CS did as far as window sizing is concerned. Hope somebody else can chime in to help you out.
...Leo
canon ­ shooter
May 07, 2007 10:05 as a reply to  @ post 3164639 |  #5
Anybody know if there is a way to set up custom workspace in CS3 so that once I max an image to edit and then save and close that image so CS3 will go back to the screen mode where the remaining images are in Casading windows as they were when first opened??
Jim
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 07, 2007 10:09 |  #6
I think you can still save/recall a workspace in the Windows menu?
mantra
May 07, 2007 11:38 |  #7
PhotosGuy wrote in post #3165430 (external link)
it doesn't save the color background
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
canon ­ shooter
May 07, 2007 13:13 |  #8
Any insight in to how?
Jim
PhotosGuy
Joined Feb 2004
May 07, 2007 19:18 |  #9
I don't have CS3. Look in the Windows menu for "save..."
Duder
May 07, 2007 20:23 |  #10
I was wondering the same thing as the OP. It's a bit annoying having to change the screen mode everytime I want to see all the images I have open.
Pete
http://www.pbase.com/p​etejackson (external link)
ohenry
Joined Nov 2003
May 07, 2007 20:47 |  #11
Just use the shortcut key "F" ... only takes a fraction of a second. I thought saving workspace also saved the screen mode, but I haven't looked at it that closely. To save the workspace, click on workspace and choose "save workspace". I know it saves the way you have the tools setup, as well as menus and keyboard shortcut changes if selected.
Duder
May 07, 2007 21:13 as a reply to  @ ohenry's post |  #12
it's not saved workspace we're talking about. say you open 10 images in photoshop, and they cascade open, you can resize the windows move them around, see all the images at once. if you then choose one image, and enter fullscreen to work on it. once you close it, instead of the remaining images being in cascade mode, the next image automatically enters full screen, meaning you have to change back to standard mode to see all the images again. This wasn't the case on previous versions of Photoshop. It's a minor annoyance, but an annoyance nonetheless.
Pete
canon ­ shooter
May 07, 2007 22:55 |  #13
Duder wrote in post #3168887 (external link)
Pete, thanks you said it better than I did. I also think it is a real annoyance, and hope somebody can come with with a way around it. I want to be able to see all opened images at once
Jim
pknight
Gallery: 39 photos
Joined Feb 2006
May 15, 2007 07:45 as a reply to  @ canon shooter's post |  #14
I have not yet installed CS3, but won't the "F" key do the trick, as suggested by another poster? That is, when you have the fullscreen image, just tap the "F" key until you get the screen mode you want. It works that way in CS2, anyway. It is not exactly what you are asking for, but it is a fast and simple way to get back to seeing the individual file windows.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
René ­ Damkot
May 15, 2007 09:01 |  #15
Duder puts it quite well.
I do want to add that in CS3 (at least the beta), you don't have to tap 'F' multiple times to 'go back one screen mode', you can instead tap shift+F once.
Still, it's an annoyance, since it's not possible to work in full screen mode, and go Window > Arrange > New window for ... to see for instance the image in full screen mode, with the same image above it (or on the second monitor) to work on a mask... (by alt-clicking the mask in the 'new window' image). In CS3, the 'new window' is also opened in 'full screen mode'. No workaround that I know of.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,335 views & 0 likes for this thread, 8 members have posted to it.
CS3 Screen Modes
2783 guests, 167 members online
