Thread started 06 May 2007 (Sunday) 19:25
make my whites transparent...
embdude
May 06, 2007 19:25 |  #1
I would like to find a method within photoshop to make the white color transparent....
I am working on a comic book- look project...
I start out with a simple image, make a new layer and use filters:
Styleistic:find edges
then
sketch: photocopy
This leaves me with a B&W image layer over the original.
At this point I would like to make the white areas clear/transparent
if I reduce opacity I loose the strong black lines I am looking for...
I know I can make it transparent if I convert to gif or otherwise but I would like a method to do this simples than having to re-open it.
Ideas???
-Chris
NEW: Photo Blog (external link)/ My Classic Cameras (external link) / Toys: Gear Sig...
Canon PDF's for EOS Digital Cameras (external link)
Free Photo Stuff Blog (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 06, 2007 19:40 |  #2
A Layer Mask is easily reversible & much better than erasing.
Airport runway shoot
Layer Mask video tutorials
http://www.heathrowe.c​om/tuts/layerthumbs.as​p (external link)
PacAce
Joined Feb 2003
May 06, 2007 19:40 |  #3
Change the blending to mode of the "sketch" layer to Multiply and that'll make the white transparent while retaing the black lines.
...Leo
embdude
May 07, 2007 00:58 as a reply to  @ PacAce's post |  #4
Thanks guys
I have played around with both techniques and find them less than ideal for my exact situation.
Custom Layer masks make it hard to write into a generic action, which I hope to do after I have fine tuned my process.
The multiply option also darkens the overall image and I am finding this reduces the effectiveness of the black lines. If I reduce opacity on it then I am also reducing the opacity of the black lines....Arrrgh!
Anyone know of a simple way to make the white transparent within a single layer in jpg?
-Chris
Tirzah
May 07, 2007 01:19 |  #5
like this???
http://graphicssoft.ab​out.com …m/joestuff/free​stuff.html (external link)
Tirzah
René ­ Damkot
May 07, 2007 06:29 |  #6
Double click the top layer.
You get a window like this:
Move the top white slider ("blend if this layer") to the left to make the white transparent.
Alt-clik the slider to 'split it up' for a smoother transition.
(on the image this is done with the black slider; had this image online for an earlier Q)
AFAIK a jpg does not allow for transparancy.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PacAce
Joined Feb 2003
May 07, 2007 14:15 |  #7
embdude wrote in post #3163702 (external link)
Thanks guys
I must have misunderstood what you are trying to do. I thought you had a layer that was a B&W "sketch" as a result of doing a Filter > Stylize > Find Edge. If that's the case, if you change the blending mode of the B&W sketch layer, the layer underneath this layer (which would be the "normal" image layer) should show up normally through the part of the sketch layer that is white without any change to the underlying image. The only part showing in the sketch layer should be the black "lines".
...Leo
RodBarker
May 07, 2007 22:55 |  #8
Go to Flaming Pear and get the free plugin called Ghost .
Rod
Adaptive
don't defend yourself, call modday
May 07, 2007 23:32 |  #9
oh wow this could be my solution to my latest prob. will it leave in detail like hair?
also would it take out white like teeth and clothing?
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
May 08, 2007 00:48 |  #10
René Damkot wrote in post #3164418 (external link)
...... AFAIK a jpg does not allow for transparancy.
You can extract part of a jpg and the background will then be transparent ... it will then be an RGB image and you are right -- it can't be saved as a jpg with a transparent background -- it must be saved as something else -- I usually use psd until I get to the final product where two or layers are blended together and then make it a pdf file because I use them in pdf publications. Also, make sure that the final product is flattened or its size will be about three times larger than necessary.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
lnterestlng
May 08, 2007 03:17 |  #11
This is the way. Simple. It's built in. No tricks needed.
1,689 views & 0 likes for this thread, 9 members have posted to it.
2814 guests, 158 members online
