Alright, well I ordered a HueyPro as soon as it was released, because I wanted a Huey but I also had dual monitors. At the time, my primary monitor was a Sony 17" LCD, and my secondary was an old 17" Dell CRT. After a few tries I was able to get the HueyPro to calibrate both monitors perfectly; they matched so good I couldn't tell a difference between the two.
Fast forward to today, and I bought a 22" LG L226W to replace my 17" Sony as the primary monitor. The Sony 17" is now the secondary and the CRT is gone.
I am having a bugger of a time to get these two monitors to look the same. I've calibrate both many times, reset both to factory settings, made sure all the software/hardware controls were the same for both. Each time I have calibrated, the Sony ends up being having more of a red cast, and is darker overall.
Is it possible that the Sony just can't hang with the new monitor, even after calibration on both? The LG is DVI, 3000:1, 5ms, and the Sony is VGA, 500:1, 20ms.
Double Negative, did Pantone ever get back to you about the issues you had with consistency with your HueyPro?
This is very frustrating, because now I can't trust which monitor is the one that calibrated correctly? I would have thought these two LCDs would be even closer after calibrating than my CRT + LCD were before.
