Thread started 04 May 2004 (Tuesday) 11:26
Canon SDK - CDStartSDK fails when called from Explorer
marknelson
Joined May 2004
May 04, 2004 11:26 |  #1
I'm attempting to write a WinXP shell extension to display thumbnails for my CRW files. However, whenever my component is called from Explorer, CDStartSDK returns cdMEM_ALLOC_FAILED. If I create a test harness and call the component from it, the call succeeds.
Does anyone know how the SDK attempts to allocate memory, or if this might be a bogus error message caused by some other failure?
On a related note, I have noticed that if my method contains the USES_CONVERSION macro, CDStartSDK will always fail, even when called from my test harness.
marknelson
Joined May 2004
May 05, 2004 07:52 |  #2
I found the problem.
As I suspected, the error message is wrong. The SDK startup failed because it couldn't load its supporting libraries (other than CDSDK.dll).
Since shell extensions are COM components, their working directory is the same as the application that created them. In this case, that application is Explorer, whose working directory was something other than the directory that contained my component.
Anyway, to work around the problem I had to explicity load all of the supporting libraries into my component and everything works fine.
PhotoSlacker
Joined Mar 2004
May 05, 2004 09:18 |  #3
Hey any idea where I can get a copy of the SDK?
(Sorry I couldnt help you with your problem)
2,012 views & 0 likes for this thread, 2 members have posted to it.
2130 guests, 130 members online
